And so the transplants begin. (Replaced blown sidelight on donor, I can't stand that!)
Now, what do you think the first thing I swapped over was?
You guessed wrong!
I also swapped this breather over from the other car.
Also the donor had these little bonnet nipple things, hopefully that reduces my bonnet rattle...
So anyway.
I began pulling off everything from the donor's door. Got this far:
Now where do I go? Everything is inside the door. How do I get to it all?
Also after much agro, I swapped this little bastard over. Many little cuts on my hands. In the end though, this one looks cleaner (after giving it a wipe), I put in the 42-LED bulbs from Cassie (one nearly broke) and swapped the little white bits inside over too as Cassie's were whiter. Cassie's old one had a really annoying issue, with the temperature dial. It'd click randomly when turned, and not fully change the temperature. Such a relief to have it working properly.
I also swapped these. The donor one is shinier! Also Cassie's has a few marks (hard to see from picture), also she didn't have that blanking panel for future goodies, for some weird reason.
Fully reassembled, annoyingly for the second time as after I put everything back together, I noticed the left knob wasn't working. Anyway, it is now. The AC light doesn't come on but I'm assuming that's because there isn't a fuse or more electrics in yet.
Finally, I swapped the interior light, because the donor had one that clicks in the 3 positions, rather than being loose and crappy. Was a bit of a fiddle with my bodgy footwell lighting, but works well now.
Oh, I continued doing something that I haven't posted about too. My passenger door doesn't seem to be quite the right shape, in a way that the door switch (for the light) often doesn't work. Previously I've been stuffing Blu-Tack into the switch to extend it, but it inevitably fails.
What I continued tonight was hammering (with a rubber door mat between the hammer and paint) the corner of the door to bend it back to shape. Seems to have done the trick, and looks much nicer too.
Sent from my HTC One_M8 using
Micra Sports Club mobile app
