Will be doing a coolant flush and a reverse flush of the system to get rid of any possible crap...Blocked thermostat? Or thermostat stuck open?
Sent from my SM-G900F using Tapatalk
I knew what you meantMeant to say stuck closed, open would be over cooled. Coolant flush a good shout too
Sent from my Nexus 7 using Tapatalk
JEETTTWASSHHHHHHHHHH sonWill be doing a coolant flush and a reverse flush of the system to get rid of any possible crap...
Will check thermostat as well
.......... if not....... ill take her of your handsOh Tom. Not much luck lately eh?
Hope all is well after a coolant flush![]()
Off MY hands?.......... if not....... ill take her of your handsx
Thought that was what ya meantWell off toms handsxxx
Ooooops! SorryThought that was what ya meant![]()
Erm... control arms...What's up Tom?
Control arms? Wtf are they? Air chisel was a good tool to useErm... control arms...
Easy job! Never!
The bolts are fused to the inner sleeve of the bush so need angle grinding out tomo till then it's up on stands like an annoying ornament that I wanted to burn today haha free to good home!
TCA chris, they control the trackI have assumed a control arm is a lower arm? I remember talk of steering arms? Confusion
Wishbones control arms suspension arms anything you want to call them Chris!Control arms? Wtf are they? Air chisel was a good tool to use
Yeah I did the steering track rods the other dayOnce it's done you'll feel better![]()
LCA?LCA is wishbone![]()
Makes such a differenceYeah I did the steering track rods the other day![]()
Then get it lazer tracked.
YupLCA?
Edit... lower control arm?
I've had a wheel wobble for a while... and been meaning to sort it out.Makes such a difference![]()
Here's to hopingBe like a new car![]()
Anti roll bar front bushings arrived today next days off will be fitted and my anti roll bar cleaned and paintedBe like a new car![]()
Its amazing the difference new bushes can makeAnti roll bar front bushings arrived today next days off will be fitted and my anti roll bar cleaned and paintedcar feels great to drive
Crank seal leaking a little now tho!
especially solid nylon onesIts amazing the difference new bushes can make![]()
Franks specials
Any news on K11 steering rack bushes Andy?Aye I've lobbed nylon ones in myself. Nylon everywhere
Just the rear one to try and make some time![]()
Well remindedAny news on K11 steering rack bushes Andy?
nylon on the front 1 (the white one in the pic) and poly on the other 2 (the yellow ones) is the best for a daily imo, when you floor the car the wishbone is forced forwards and because the poly ones have a s/s insert that is,nt bonded to the poly, that poly flange was chewed away within weeks on mine (the stock insert is bonded into the rubber, so you dont get that wear problem)Aye I've lobbed nylon ones in myself. Nylon everywhere
Hint hint hahaWell reminded![]()
the k10 rubber rack mounts are notorious for failing the mot anyway andy, and you have to be careful with the poly bushes that have the (unbonded) s/s insert eh, because the forces are concentrated in 1 small area (the big arrow) where-as with a bonded bush the rubber is pulling and pushing against the forces (the little arrows)Mines got the standard rubber rear at the mo. Have to say its not too bad, steering rack bushes are more important for me first, eliminate the slack you get while the bushes take initial load, its minimal but will help![]()
Must've been lucky for me then as my rack bushes are in good nick, but they are only a year or 2 oldthe k10 rubber rack mounts are notorious for failing the mot anyway andy, and you have to be careful with the poly bushes that have the (unbonded) s/s insert eh, because the forces are concentrated in 1 small area (the big arrow) where-as with a bonded bush the rubber is pulling and pushing against the forces (the little arrows)
which is why i have advised members to go for the very stiff grade of poly, on a few threads on here
Thanks AndyLooking forward to this Tom![]()
Did thanks chapThanks Andyhope you enjoyed ur b day!
Get anything nice?Did thanks chap![]()
Haha nice one chapChocolate, mucho chocolate
And a spark plug that lights up.. because I always seem to have a spark plug in my pocket
Oh and a banner
Big one on the side wallsHaha nice one chap![]()
I've got odd nuts and bolts in my pocket all the time haha.
Banner looks the part.
Can't wait for BSR to be up there! That will look the balls!
