h701micra
Deactivated Account
Of course we don't mindI don't use Facebook soo thought one ickle post wouldn't hurt and no one would mind to muchx
Likey rubber hose from the back of the trottle body?vac leak maybe tom ?
IACV?Gentlemen millie has a little idle issue come to a stop at traffic lights or parking and she sits at 1500 everytime then slowly settles to 900 until I come to stop again.
Any ideas?
Possibly scott ill have a proper look next days off.IACV?
If you've removed it recently make sure you didn't trap the O ring !Possibly scott ill have a proper look next days off.
not if its not drinking coolant, noThink I should be concerned?
This would explain improved throttle response and the feeling of more torque at 60mph+Pressure is one side of it, air flow the other. Engine vacuum has to do less work drawing air in of it's already traveling into the engine at 60mph eh
And why I could do 120+ indicated in the white oneThis would explain improved throttle response and the feeling of more torque at 60mph+
Need a cloder one ideally mate im thinking the t and 1 white and R in red...Like that Tom?
Best photo I have unless @Enuo or your very fabulous @Clodo has any from JAE when we had a colouring session
Edit: mine are 195/50 but there aint much in it![]()
No worries budMaaaaad cheers boss![]()
What size are your tyres mate would you say theyve got a square profile? If that makes sence.No worries bud
Any more let me know as I'm floating about at the mo![]()
Love the tire paint, it'll look great on your car Tom, I'd do it myself if I had a brand of tire someone had actually heard of ..
No trouble mateThat looks perfect mate thanks![]()
where did you wire the leds into?.Ok, funny few days really... started with led footwell lighting.
And bought myself a backbox for £10 yes just £10 its a RAGE box with 5'' rolled tip...
Cant wait to get it on... clodo says will I be renting it to homeless people to sleep in when its raining...
Over and out.
Below half on mine
New boots for the old girl ordered![]()
Toyo T1R 195 45 15 lower profile than before cant wait! now heres the question...
I dont suppose any of you nice people with these tyres can post a pic of the side wall I might be thinking about tyre paint... just want to get a quick look myself before I buy the markers
Cheers fellas![]()
Is that when stationary or when on the go? When stationary, its to do with what temp the rad fan kicks in, which can vary a little bit depending on the temp sensor as they won't all read EXACTLY the same...Could this be because of engine modifications? As mine sits the same as Toms.... x
She's had practice. I'll be her reference for the job if needs be TomDoes this mean you'll let me loose with the tyre paint! .....x
Tried a new engine temp sensor? Coolant mix could have an effect maybeBoth of ours sit there when were on the move x
Mine sits around about there , fairly fresh coolant , while drivingCould this be because of engine modifications? As mine sits the same as Toms.... x
I dont use the cigarette lighter ever so thought why do I need a light around it so I can see it at night... cut the wires and spliced into the light port on the ciggie lighterwhere did you wire the leds into?.
