I believe they are the same as mine custom jobs made by a guy on retrorides I sent pork the link in one of his threadsWhat arches are they ?
I can't remember mine are the bigger ones his were the smaller ones lol don't remember which is whichyeah aren't they style 1's? they look bloody mint in white with black arches imo.
HAD a go at the rear arches today, took bout 1 1/2 inches off, so no mire scuffing and the wheels turn round at the height I want, which is a bonus
These were the style 1 arches from the dude off retrorides
Sent from my iPad using Tapatalk
did you need much work done to them? like bending or anything?
Beings I wanted to go as low as possible, I had to cut a couple of inches off the metal arch, the way I did was cut more from the outer arch, then folded the inner arch over it and pinched it all together.
There's a few pics earlier on in the blog.
Jus make sure you when you get the bolt on arch, spend time getting the correct 'line' on the body, to high and u will have to cut loads more arch off, to low, it will just look wrong.
Hope this helps.
I sort of regret never trying to pull/roll the original arches out, with the coil overs on the front, I had a couple degrees off negative camber, and could defiantly rolled the arch to make it fit
Rears a bit difficult to get the same camber (machi San managed it, bit to technical for me tho)
Depends what you want really, I only got the arches because I couldn't do It how I wanted too, but the result still looked cool
I used polo 6n coillovers, and slotted the top hole inwards a d welded on a washer for a bit of strength![]()
Yeah looks fine
This is my new k10, paid £400 for her with 37000 on the clock.
grille still of as the paint i used came out like magnolia?
jus ordered new shocks and springs, undecided on what alloys to go for, big and badass, or some nice deep dish wheels, wanted superlites but it jus aint gunna happen is it
il keep u updated as it goes!:blues:
Got these in post today:grinning:
Also, had big dent on the boot by the number plate lights so bashed it out, Iv tried spraying it White before with rattle cans but it kus doesn't match. Iv seen someone paint this matt black before so I gave it a go, not to sure on the result.opinions please
Painted up bumpers to
