pork
Looking good Neil![]()
Getting there, really wanted it all back on its wheels so I can roll it to the workshop again
But I messed up the driveshaft thread !
how does the ball joint size affect the shafts?
It doesn't affect the shafts, it's the whole hub/carrier assembly which has different ball joint sizes
i know i was asking about shafts and you mentioned ball joints :s
I had a k10 ball joints in the k11 hubs for a bit![]()
Any further updates on ignition side of things mate?
Haha, just read back thru posts, sorry, read it wrong, long day.
The shafts are the same length, it's the hub spline diameter on my early k10 that are to small for the k11 hubs
At some point on the facelift k10's they changed the spline diameter
ah i see just my late k11 huubs fit my k10 shafts![]()
U not using them now, what you got instead?
Megajolt is tried n tested, better still if you can pick it up 'pre-loved'Was gunna do aldon thing, but gunna go with megajolt
But found a second hand kit on RR, but il have to see if it's still about next month
I've welded brand new k11 ball joints into my k10 lower arms. Seems to of been alright for a couple of days now![]()
Megajolt is tried n tested, better still if you can pick it up 'pre-loved'![]()
True!! £200 he wants which ain't too bad
Is that everything you need??
You could just buy an aluminium trigger wheel off eBay and just bolt (ish) it onto the bottom pully![]()
This comes with the suspension set up? Is it the polo 6n set up?
Yeah![]()
You could but it won't work, it needs to be steel
Mine is just bolted on
I didnt need the outer section of the pully did I chopped it off and just bolted the trigger wheel on. The pully bolt goes through the wheel to clamp it in place then the three m6 bolts stop it from twisting.
Try the back wheels on the front? The offsets look different
Same thing I had, in the end I used the K11 alternator. Wirings fine, I'll just walk up the road and take a picture![]()
Ok from K10 to K11;
Fat white -> Orange/Black
Skinny white/red -> Yellow/Red
