I like the idea Paul but.........so a few months ago I printed these replacement plastic mounts for a m8s glass sliding shower door
View attachment 60106View attachment 60101
but the heavy weight of the glass had cracked the weak PLA plastic
so I redesigned it out of really beefy stainless steel to ensure it's strong enough this time
View attachment 60103View attachment 60104View attachment 60105
cutting some 8mm thick stainless bar for the bracket plates.
it's abit OTT but best to overengineer it
machined the supporting collars that fits over the ball joint
drilled the plates
tapped
machined the socket screw heads smaller so they don't foul. the two screws fit into the oval glass holes which keeps the bracket upright.
View attachment 60111View attachment 60112
welded up
and rounded the corners
View attachment 60114View attachment 60115
Nice that does look very clean!
You are now putting a LOT more weight onto the glass panel, which I assume hangs from the fairly flimsy frame/track. This will be the next failure point and not so easy to fix.........![]()
I thought that you were going to base the rebuild on another auto block Paul? How will the open deck block stand up to the high state of tune that you had before?
That engine looks like a great findgood luck with the rebuild, glad to see things are moving in the right direction again for you.
Sent from my SM-G901F using Tapatalk
I have never seen a CG engine that clean when opened up before.
Are you forging this engine Paul or just stripping it down regardless?
An open deck block will be more than up to the task of ~160bhp![]()
I'll check my CGA3 that's up on the engine stand as a comparison, just for the fun of it. The only obvious difference on the later blocks is the inclusion of a mount point for a knock sensor.
I've noted that the numbers on the engine are fairly meaningless with respect to dates. On the later coilpack engines, there's actually a stamping on the cam side cover which has the year/month of manufacture on it. The last CGA3 donor engine I bought was a 2002 unit, so fairly late.
Had you considered, Paul, that the difference in timing chain guide wear could well be due to the better lower sprocket lubrication on the old engine? Did you drill & tap the boss on the new block and fit the oil jet from the old engine?
It's never ever overheated at all so I think it opens far enough for normal use but just not ideal for max cooling on track.Do you think the partially opening thermostat caused you issues? We know number 3 is the weak spot, and my old rally engine the paint around no 3 flaked off with the heat but the other three were all ok. Is there an issue with the water flow around no 3?
Hello Master Paul first of all you are doing a great job as usual.I plan to replace all the ferrous steel pipes in the cooling system (which tends to rust & contaminate the fluid) with stainless/alloy so the coolant stays cleaner for longer.
clamped the thermostat housing steel pipes in a vice & twisted em off
machined & inserted the new alloy ports
View attachment 60297View attachment 60298View attachment 60299
testing the thermostats and the genuine one from the spare engine worked perfect so I'm reusing it, whereas the aftermarket stat from the blown engine no longer opens fully
View attachment 60300View attachment 60301
fitted the stainless manifold studs
View attachment 60303View attachment 60302
Cheers, they're simply tolerance fittedNice work again Paul.How have you retained the new aluminium pipes in the thermostat housing?
I think I would have put a couple of shallow grooves in each pipe and used some Loctite
Studlock, then pushed them into the housing..............
The secret of getting a good interference fit without any loctite or similar would be to make the tube at least 5 thou bigger than the hole in the housing, then put the tube in the freezer for a couple of hours and heat the housing in boiling water, same principle used for shrink fitting the ring gear on a flywheel.......it was quite a tight fit to press in, like the originals so I think it'll be alreet. pretty difficult to get em back out without wrecking it![]()
That was my assumption as well............hence my concern about how firmly the replacement aluminium pipes have been fixedI might be wrong but I'm fairly sure the steel pipes are cast into housing originally.
just a regular 82c statthat the hotter saab thermostat again ?
