Bad news that Paul. Might have dropped a rod eh. I'm sure you'll sort it all out over the coming days and it'll be better than before.
Sent from my WAS-LX1A using Tapatalk
Nope no spare block hereThat's bad news Paul, looks expensive!Hope you have a spare engine for a rebuild..................
I sure hope it ain't the expensive bottom end. The block or sump or oil patch doesn't seem to show any damage, yetBad news that Paul. Might have dropped a rod eh. I'm sure you'll sort it all out over the coming days and it'll be better than before.
From your description of the train of events Paul I can't see your 'best case scenario' being plausibleNope no spare block here
Best case scenario is I just need to grab a spare bung plug that's fallen out and the bearings etc are fine.
Worst case is major damage and may have to consider reverting back to a standard block.
Sent from my Nexus 7 using Micra Sports Club mobile app
Sadly Paul, from your description of events, that was to be expectedupdate soon and the news ain't good![]()
Agreed, I'm about to start stripping a CG13DE Engine and gearbox so may have some internal parts you might needWhat's the news Paul? You may find members of here may have parts you need...
The oil in the bell housing is likely from the crank oil seal which probably distorted when the rod was about to let go ........Hi been soo busy & tired with work & stripping down this engine but here's my findings...
looking under the soaked bay for where all the oil is coming from, the first clue is this bracing bar bolt hanging loose?
View attachment 59725View attachment 59726View attachment 59727View attachment 59728
this is all the engine oil that remains
gearbox drain with the usual amount of debris
began stripping the bay to investigate further
and oh no, seeing part of the sump exposed is not what ya wanna see
View attachment 59732View attachment 59733
turbo removed for a better view
ohh ####cylinder #3 has clearly thrown a rod
View attachment 59735View attachment 59736
removed the engine
View attachment 59737View attachment 59738View attachment 59739
clutch is fine, only an oily bell housing
View attachment 59740View attachment 59741
the oil gallery bung plug is still there but looking further back, holy crap there's an even bigger problem with a chunk punched out including the oil gallery!
oil filter internals seem fine with only tiny bits of metal from the disaster
clutch is in good condition with plenty of life. just one of the plate springs is slightly loose rattling about
View attachment 59744View attachment 59745View attachment 59746
back of engine is oil stained but dunno where it's all coming from tbh. that big oil gallery plug ain't leaking
Back in the dim distant past (50 years ago!) when I built my half race 850cc Mini engine, I had the con rods shot peened and polished and the rods, crank pistons and flywheel all dynamically balanced. The rods had pinch bolt small ends and the gudgeon pins rotated in the pistons with no small end bearingsbut the engine revved comfortably to 8000 rpm, though I decided that 7500 was safer so red lined it there. Not sure where you would go to have the internals treated the same way these days, but with long term reliability in mind perhaps this would be a way to go?
Well that went properly!
Sorry to see it, what are your next steps? It's horrid when engines go like this, been there this time last year....
Plate diff's always wear out, so rebuilding will always be part of the maintenance plan, the threadlock you use on the diff will need to be special 'oil proof' stuff, normal stuff is not designed for immersion in oil...
Hard lines mate.
#### happens and life goes on though hey, you've pulled your finger out, got on with it like a boss and assessed the damage, good attitude.
On a side note, what a good mate you are- just had your engine throw a rod, clearly spent some time stripping down etc and still sorted your mates steering wheel out- more people needed like you man.
Good luck with it.
Sounds like a good plan, time to find a 1.3 auto which has failed its MOT...
Though they are rare, could you use a 1.0 auto and transfer the crank and rods etc.. from a normal 1.3? TBH I would just use a good condition 1.3 engine regardless of it being auto, the engine condition being more important than the auto part...
Another reason to fit the Whiteline castor/traction kit Paul. You can increase the castor which provides significantly better turn-in and steering response over stock.
Is the ratio actually any different? The castor kit is a very worthwhile investment.
You seem to be spending a lot of time and money on not getting the engine fixed Paul....... ( or are parts in transit?)
I used Lodexol once and from that moment on I never used it again as it simply never performed well when I had a Gripper LSD.
I always used 75w90 GL4, (which is what my Nissan manual recommended). I would then tune the response with Redline friction modifier, which worked a treat for me.
Matt H recommended ATF Oil for our rally gearbox with the Suretrac LSD, and 4.92 semi-helical final drive. Cheap enough.
ZR with Quaife LSD uses expensive (£9 a litre) Castrol Racing Gear Oil
Good move away from stainless, your lockwiring skills are great.
