You can increase caster using using an adjustable mount for the rear mount on the front wishbone.
More likely that the suspension mounting points on the chassis are slightly out to the body panels....after swapping the wheel studs on the other LH side and fitted 8mm spacers on all wheels, gave her a good wash on a nice day and obviously had to take a photo
View attachment 54212 View attachment 54213
I think the LH lower arm is slightly longer than the RH arm cos both front wheels have the same 1.2deg camber and yet the RH wheel sits in the arch like this,
whereas for the LH wheel, I actually had to adjust the top camber plate outwards (whereas the RH camber plate went all the way inwards) in order to match 1.2deg and visually the the wheel seems to poke out 1-2mm more?
I'll have to measure if both arms the same length and if the arm mounts are both equally the same distance from the sills/arch
You talk about stiffening the rear to reduce understeer/induce oversteer.
You probably know this and I may be stating the obvious.... But increasing the rear stiffness reduces the rear end grip and this only makes it understeer less because the rear loses grip first.
This will ultimately make it slower, but feel better to drive.
Hopefully that makes sense
Sent from my LG-H850 using Micra Sports Club mobile app
I was going to suggest more tires but given how close it is to the inner arch this would probably need new wheels... So I won't.there's only a limited amount of ways I can max out the front grip without more extreme measures like different tyres or....
I understand why you're starting stiff then working it off but I think I'd go at it the other way, loosen the arbs right off then stiffen them up where you need to get the balance back.my current thought is start off too stiff at max settings to limit roll, weight transfer, tyre flex (tbh I'd like to fit stiffer springs) and slowly soften the front end to regain front bite towards neutral/oversteer feel.
My first thought was to stiffen up the front shocks but I think that would potentially lose grip as well.
You said it understeers on exit as it loses grip, there should be as much or more grip with the swaybars off...
What's your wheel alignment settings? My mini magazine says reducing front toe out will delay turn in but it's quicker transitions we seem to be after. Rear toe out can induce oversteer but you only want a tiny bit, but I guess with beam axle it's fixed.
Is it the front, back or both that is taking longer to settle into the corner Paul?
That sounds like the rear roll centre could go higher, ie the centre of gravity has quite a bit of leverage and therefore has to move further until it encounters resistance from the springs, it's also going to mean it compresses the outside spring more...when I turn, it takes afew millisecs for the car to roll, settle, then react. it turns in nice but if I push too hard, the front end easily overloads and understeers first before the rear.
when I wiggle the steering at speed, the rear end is quite wobbly.
Good conversation, thanks![]()
Why 0.20 toe out? On a fully poly bushed front end I would go with 0.00 toe i.e. dead straight
when the car is static, the panhard is flat meaning the roll center (about the middle of the rod) is exactly level with the rear beam axle while the CoG is around the height of the rear seat backing.
perhaps move the rod mounting further up the chassis?
If you can without the panhard rod creating weird suspension behaviour, I understand they are best behaved when parallel to the ground. It would possibly tell you if it's worth pursuing developing a watts linkage.
As a smaller move I might test the car with no sway bar front and either the standard rear sway or the whiteline on the rear, the whiteline is likely to be overkill with no bar on the front but it might tell you better which end the body roll is coming from. Looking at the photos above in gentle curves there's a difference in roll at the back but not much at the front and then again in a harder turn they don't seem too different as the roll has settled on the springs.
I'm not much with adjustable springs(never had them) but would adding preload at the back help? ie it settles on to a harder initial spring, it may also bring it back to neutral steering but likely loose rear end grip a bit. Just thinking...
Mazak, a very cheap zinc based alloy, or as it is 'affectionately' known in the trade, 'monkey metal'my £50 old rotary laser level for leveling my alignment platform was having issues spinning, like not enough power (even with new batteries) or bearing was sticking abit.
didn't have time during the day to fix it so continued aligning my wheels with the previously levelled platforms.
so obviously I took it apart to try lube the bearings and then this damn plastic pulley broke
so had to machine a pulley out of some spare bits
but it was too tall
so tried to pry it back off and the damn cheapo shaft broke
damnit so I'll have to take it all apart and remachine a whole new shaft/pulley.
I had to break apart the shaft to remove the bearing and omg this is where they cut costs alot in material choice.
they literally made it out of what I can best describe as shortbread biscuits lolcan almost snap the pieces with fingers
View attachment 54309 View attachment 54308
guess I'll be rebuilding my laser level after the trackday.
Mazak, a very cheap zinc based alloy, or as it is 'affectionately' known in the trade, 'monkey metal'![]()
I think that would be a good next step, especially as it is reversible. I figure you'd want to raise the mount twice the height you want to raise the roll centre.I believe there's space above the original panhard mount to redrill and mount it higher & closer to the chassis rail to alter rod angle / roll center.
Everything is happening at one end in that situation so it seems inevitable, if it wasn't you'd be going faster in which case the same thing would happen at a higher speed.On track, she understeers abit during long fast bends no matter how much I soften the front pressure or dampening.
When you fill the ends Paul, leave a central 25mm or so round hole in the centre of the closing panel, which you can later seal with a rubber bung, for access to spray Waxoil into the cavity and prevent the chance of future rust in the same area......completed welding the sills to the chassis.
while welding the inner sill, bits of the sealant used to seal inside the cars floor had caught fire repeatedly and damaged my boot/fuel filler remote handle abit :/ had to put fire out with water sprayer after each weld.
grinded the welds flat, and painted
just have to cover the ends tomorrow and it's finished in time for saturdays convoy to the scarborough cruise meet
Yeah that exactly what I'm doing to my recently done sills, have to be careful to make sure that they're a good fit though because they're right in the way of spray off the wheelsWhen you fill the ends Paul, leave a central 25mm or so round hole in the centre of the closing panel, which you can later seal with a rubber bung, for access to spray Waxoil into the cavity and prevent the chance of future rust in the same area......
