If you are machining critical suspension components yourself Paul you need a suitable high tensile steel ! See HERE. The sort of easy machinable mild steel that you probably have got is NOT suitable!ordered a pair of GE12AW steel-teflon lined spherical bearings and some 50mm steel rod to machine
after a 1000mile return trip down to japfest, the catchcan only caught 96ml!
something really ain't working right so gotta check that out. maybe machine the container out of more conductive Alu/steel
Critical steering/suspension components are usually cold formed/rolled, which imparts extra strength to the component, forming the grain structure of the material within the shape of the component, not by turning/dieing, which cuts through the grain structure, weakening the part. Also strength critical parts are usually heat treated to specific hardness/toughness parameters after the forming process....(I was, for the last 11 years of my working life, prior to retirement, a designer in the automotive fastener industry and amongst other things, spent many hours doing tensile tests on batches of components, failing quite a few that had been incorrectly heat treated or manufactured by far eastern sub-contractors from inferior grades of steel....)
I wouldn't, too many unknowns.i already just brought some EN1A bright mild steel off ebay
http://www.ebay.co.uk/itm/291541838286?_trksid=p2060353.m2749.l2649&var=590599586376&ssPageName=STRK:MEBIDX:IT
what grade & source dya recommend for machining & welding onto the lower arms?
I wouldn't, too many unknowns.Recipe for disaster in my opinion, it's one thing to make and fit spacing parts, securing original components with like, but longer, high tensile bolts, but to make totally new critical components without a great deal of knowledge about metallurgy/material properties and the stresses that the components will be subjected to is bordering on insanity!
I thought the ball joints didn't come out!
I'd go back to looking if there's any other ball joints that use the same taper, I was thinking if the nut bolting to the hub is the same size the taper is more likely to be the same as well. Trouble is searching on parts 4 u lists a heap of models using the same nut but I'm not sure how to work out if they are used on a ball joint. I can't remember is it a castellated nut?
Paul, how are you filling the space around the clamping bolt, left by the tapered ball joint? At the very least you will need a hardened, tapered sleeve slid over the bolt... I do hope that your welding skills are good enough to attach the top retaining collar to the lower suspension arm, a failure there would be catastrophic!the GEH17C bearing & inner circlip arrived
looks like a steel outer casing with a sintered bronze & PTFE lining. swivels very smoothly
it slots into the lower arm hole like a glove
a bonus is that the 12mm high bearing case sits just about flush with the original bore on the arm
so I simply just need to machine some retaining cups at both ends and the circlip sits' like this
the original ball joint sits like this with 24 deg of swivel
View attachment 53898 View attachment 53897
here's the new arrangement.
- GEH17C spherical bearing (red/green) sits inside the existing hole on the lower arm (white),
- the upper retaining cup (yellow) is welded onto the lower arm. it transfered upward bump forces from the bearing to the arm and holds the rubber dust cover/boot.
- the lower retaining cup (turquoise) is welded under the arm and keeps the bearing retained via the circlip (grey) to transfer rebound forces to the arm.
- extension collar (blue) lowers the ball joint by 40mm and transfers vertical & lateral forces from the hub to the bearing.
- the lower collar washer (yellow) and extension collar (blue) clamps onto the spherical bearing.
- high tensile M12 x 120mm bolt (orange) keeps the whole assembly clamped tight onto the hub and transfers the bump forces from the hub to the bearing.
View attachment 53899 View attachment 53900 View attachment 53895 View attachment 53894
the bearing also has a much wider 38 deg swivel range
now I need to find a suitable CV boot to cover the joint
Better Idea Paul, though don't just drill out the arm with a 16mm drill bit, you need a really snug (slide) fit with the bolt shank, so better to drill undersize and ream the hole for an exact fit to the bolt.updated the design, I'll be using a beefier M16 bolt so the head covers more of the ball bearing edge and I'll be drilling the hub with a straight 16mm bit to fit snug against the bolt. my welding is fine, I've rewelded these arms before and zero problems after so many trackdays.
As well as the top rubber cover to the joint you will also need a cover for the underside to keep dirt out of the ball joint.........
Wrap exhaust heat wrap around the ball joint, and use a metal 'zip tie' to hold it in place.
I was meaning you use the heat wrap to protect whatever rubber boot/gaiter/tube you use.
You are pushing your luck there with those wheel nuts Paul!(especially if the new chrome, after market, ones are not to the same hi tensile strength as the old OEM ones...ever heard of 'hydrogen embrittlement?)
Your choice Paul, I don't believe in taking chances on safety issues......I've used steel nuts from ebay for years & many trackdays with zero issues
With full thread engagement the chrome after market nuts are probably perfectly OK, but with the minimal thread engagement on your front wheel studs you are taking a risk that could easily be be averted by fitting longer studs.....
But I thought you had fitted longer hub studs Paul ?
I would say that you have been very lucky Paul, there are 'after market nuts' and there are 'after market nuts'!ever since I fitted these alloys 7 yrs ago and pushed them hard on track it's always been with these aftermarket nuts threaded in by bout 20mm and it held up perfectly fine so they're well up to the task.
but yeah now that I know the fronts are only 1/2 way in, I'll upgrade the front studs too.
I wouldn't cut the lip off and re-weld it Paul, most of the strength comes from the forming process.........
What is the idea of the cone shape on the extension? I understand you need it to keep the movement, but why not have it the same dia. all the way up?
Nice job with the MIG welding Paulpractice & setting up the welder on the rusty arm. stick welder was too inconsistant, uneven, hard to control and sometimes blowing holes during long runs as heat builds.
so dialed in the MIG welder instead and it does a much better job, good penetration, consistant & even appearance with little clean up, especially handy for the tight areas.
reinforced the rear peg of the spare arm
carefully welded the retaining cups of the left arm
and right arm
both arms welded up
Nice job with the MIG welding Paul![]()
Pictures not showing Paulmachined the new studs down to length
Received new wheel bearing
Hammered the hub off
A slight ding on the hub from a previous removal
There's the cause of the right turn whirring noise, same defect as on the rear hubs
Tried removing the outer race but I don't have any round steel large enough and it's pretty stuck so will take to a shop
