Hi I have a hilix clutch what pp did you usefitted flywheel
centre clutch on PP
View attachment 36718 View attachment 36721
fit onto flywheel
test fit gearbox & starter
View attachment 36720 View attachment 27912
to make sure nothing fouls the clutch
View attachment 36714 View attachment 36715 View attachment 36716
Sent from my SM-N910F using Micra Sports Club mobile app
Cheers for reply I better get searching for 1it's the 200mm helix organic racing clutch kit from matt humphris.
didn't have any ID on the PP
Thanks mate appreciate itcontact matt for detailed info
http://www.humphrisoxford.co.uk/rally/
On my doorstep, literally a minute from my houseeasy one for me
Sent from my LG-H850 using Micra Sports Club mobile app
erm has JAE moved venue again back down to the midlands at peterborough? early morning for me
was that before kettering?Ah, so they've gone back to a former venue (East of England Showground).
That may very well change my opinion on attending...
If you are that worried about shell flex, then get a proper cage in it. You will be amazed how much flex is going on that you don't notice now. Plus it will make the car safer...
Thanks for the offer DanielHey polly, if you need an AVR ISP, I can send you one for free. PM me if the arduino doesn't work out!
Could I ask where you get your metal supplies from?
Loving the removable X brace Paul! I'm quite surprised how much chassis flex there is in a 5 door!
I may have to look into making something like this for my K10 as i'm sure it has less rigid chassis than the K11. You can feel the whole car flex if you go over a speed bump at a funny angle!
i know you prefer your mig but have you tried stainless steel arc rods paul ? the welds are 10 x neater than mild steel arc rods
I like your testing method![]()
notched the final top tube
tacked
welded it up. ain't half bad.
seriously need a less-tinted welding mask cos I really can't see where to weld, so I can't weld continuously and have to pause alot which results in ugly pigeon poop that annoys me
my usual preferred method is pulse welding which helps keep the weld looking consistant and controls heat but I found at the machines maximum setting, the molton globs tend to clog up the MIG gun badly and frequently jams it. and then the porous weld bubbles up while cooling due to lack of gas, so had to grind and reweld.
need alot more practice imho
to test how much the chassis twists without the brace, I opened all the doors, left the boot open marked with masking tape and jacked up one wheel
without bracing, the boot has skewed over by 7mm!
bolted the X-brace in, it's a snug fit to get all the bolts lined up
View attachment 52798 View attachment 52797
jacked the corner up and oh gawd, it's barely moved 1mm.proof it works
comparing weight, all this rear seat & shelf weighs a hefty 22.7kg
while the X-frame only weighs 7.1kg
a reduction of 15.6kg for a stiff chassis!
took it for a drive, dunno if it's a placebo effect but she feels nippier and tighter.
the delay between steering input and feeling the weight shift definately seems sharper and the rear end is feeling abit more loose on these cold old T1R tyres.
road noise is definately louder, exhaust is boomier and stereo is pointless, so will need to wear ear plugs with this layout.
give it some paint tomorrow
https://www.amazon.co.uk/Parweld-XR916H-Autodarkening-Welding-Helmet/dp/B00GJX0BAQ
Hands down my best purchase. This made my welding a million times better.
