the manifolds been leaking & could smell it so off it comes
yep been leaking heavily round the weaker warped front/rear sides
for easiler access to a stubborn blocked nut at the back of the flange, I grinded this edge of the manifold smooth to fit my fingers through
a look at the crack below the prev welds
grind it all back reveals the gap
after several rusty welding attempts, figured my best method all along was the old 1sec pulsing motion
to try flatten the very warped flange, fixed a g-clamp on a pole to counter weight the manifold and spent hrs sanding it, got close as I can then gave up lol
smear of copper sealant
that nut bolt at the back of the mani flange is always a pain to access with normal long spanners so modified an old one
assembled
lets assess & clean the alloys. the melted power coat had briefly bonded the alloy to the disc so a hard yank got it off and yeah the melted hard paint will need chipping off
got a bottle of that wonder wheels spray stuff in halfords that antony suggested, got the very loose surface brake dust off but it looks like the power coat was actually still uncured soft when I was bedding the brakes and the red hot discs really softened it allowing the dust to simply embed deep into the paint so none of the weak dishwasher soapy stuff will get it off.
even tried stuff as harsh as oven cleaner but that just left some water-droplet like dots all over the black dusting.
only thing that came close to removing the black haze to reveal white paint is carb cleaner with a clean rag but that actually Melts! the surface into a sticky tacky goo, attracting more dust.
so I ruined my new wheels then, best leave it now
in the aftermath of finding out I've been friendzoned other night and basically felt really really down,sad, angry n depressed, sitting around just made feeling worse, coulda almost cried..
needed to get away (crazily thought of driving 5hrs down to hand over her bday prezzy then leave, even after I said to her I best not go to save my sanity, but that would be crazy wouldn't it? as some say that high emotions = low IQ, I was a thick upset wreck that day)
instead went for some random long drive down at the twisty hilly whitby & moors for a hard blast to release steam & enjoy driving
boosting hard up a long steep hill obviously blew the turbo mani copper sealant again but meh. stopped over to check things over
spotted the ground wire on the alternator had fractured off and could've drained the battery dead once again like recently
so roughly stripped & reattached the remaining wire to get home, then watch eurovision with the lads for a laugh
