does changing the engine oil make any difference to the way the clutch feels? changed the oil a couple of days ago and now the clutch feels really smooth! doesn't seem to bite harshly anymore, or is the clutch on the way out?
I run 5w30 in mine which is the 'correct' oil for it. At 60,000 miles, your engine will still be tighter than a knat's chuff and shoud be absolutley fine with 5w30. If you had any oil in the clutch, you'd notice a terrible smell and the clutch would slip. If you read the 'Bob is the oil guy' forums, the Americans and a lot of the top car manufacturers are going over to 0w20 oil. The lubricity's the same but the oil can get around the engine so much better that heavier oils .
