hoodedreeper
Hello all! I've got some Micro LEDs that are currently being fitted to my Micra.I got given the layout of the wiring:
This is what i've done so far....
- Live wire running from the battery (+) to the fuse....then a live wire running from the fuse to the switch
- from the switch i've got a negative wire back to the battery (-), an earth wire from the switch to a metal bolt
-from the switch i've got a live wire running to the terminal block
-from the terminal block i've got the neons connected
The light on the switch now comes on because its earthed.Theres one more 'pin'/connector left on the switch but i dunno what thats for.The neons still dont work
Can anyone shed some light onto this problem?
