Thought I'd do a little write-up/update about Sunday and the Auto-Triathalon event me and @
pollyp attended
Sunday morning and it begins at 7am, first task was to bleed Paul's rear brakes, so on the roadside at this hour on a Sunday it was a sight for those that did pass us. Brakes done, Paul much happier with the pedal feel, Job Done.
Next was to load all the bits n pieces I like to take while on an event which didnt take long as it was pretty much prepacked stuff, oils, fluids and some tools
Arrived at East Kirkby airfield at just gone 9am, nice steady drive, with one small burst of throttle to clear out any crap along the way.
Signed on, got our route map and a time card. Had a wander around the circuit, jeez its tight only 12inches of space at most either side to get through, the 2 classic minis that arrived had it easy. The BMW 5series estate, Gen 6 Celica and the Honda Accord had a bit more to worry about.
After the walk around the route I thought it will be easier to memorise if my passenger could read the route out in simplified pace notes, he's never nav'd before so I couldnt ask him to do turns in numbers. Pace notes made. Time to queue up and in good H701 fashion the start button was pressed and nothing, zilch, nada, nope. Quick bumpstart and decision made that a new starter was in order, fit new one, refurb old and keep as spare.
Paul was sharing my passenger so as soon as I crossed the finish line, Rob would have to jump out and zip over to Pauls cars and do it again (along with my pacenotes, cheeky)
Event 1 - Slalom course, measured in points not time
First Run on event 1:
Terrible, first section was simple enough after that I'd got myself lost and amongst the en masse of cones I pointed the car at slightly the wrong on the exit from gate 7 and ended up backwards through gate 10. This was the section we was warned about 8-12 was the hardest part of the course and a slight misjudgment can ruin it. Ah well rejoin and carry on, too tight in to go through those tight gates, skipped over to 13 and carried on, right left chicane followed by a long version of the chicane we just did. Onto an anti-clockwise 270degree turn, pulling the hydro and the mech handbrake and forgetting to let the mech handbrake down again meant we did the rest of the course with it on.
Few 90s into a clockwise 270 degree turn, round in a type of S to the finish
The car was setup to grip, not slip so getting it to slide was going to prove difficult, the amount of grip my car had over every car there became apparent on event 3
Run 1 - 1:50 and 7 penalties (3:00).. this pretty much put me badly out of the running for a 1st place finish, top 10 becomes the target of the day
Second Run on event 1:
Notes cleared up, Nav speaking slower and more clearly, Tyres warmed up, Brake Bias adjusted for more rear braking, Me learning how to handle this new build alien car and partial memory of the circuit meant we cleaned the circuit with 0 penalties and shaved 5 seconds off. Still not a great time but as each penalty is worth 10 points and least points wins. We had technically shaven 75 seconds/points off the time
Run 2 - 1:45 and 0 penalties (1:45)
Third and final Run on event 1:
Time to push the car, see what it really can do, Nav repeated his previous note reading slight adjustment and highlight some key points on route, car setup left the same.
3, 2, 1, Go and we were properly off this time, route was becoming familiar with reminders needed just incase. Brake bias was perfect and the Hydro handbrake came into its own. Unfortunately on one turn we just nudged a cone, it happened just off camera on the (only) video of the run.
Other than that it was a perfect run, cocking a rear wheel left right and centre
Run 3 - 1:25 and 1 penalty (1:35)
I think one more run and I'd have another 10 seconds off that time but ah well, time for the car to cool down, realise I'd ran the event on the tyre sidewall on one tyre, but not on another where it has more camber (dodgy wheel alignment but it was good for testing in the end)
Had unconfirmed sayings of it being the fastest run of the day all penalties considered. If so, great
if not, still great
Modified route map
Event 2 - Blinfolded Driver Test
Simple navigate through the cones that were only 6 inches wider than the car itself, each car was measured. Event was timed neither.
Except I was blindfolded and it was down to the nav to get me through. Having done a similar event before I passed on my hints n tips to my nav and he picked it up straight away.
Finish with 0 penalties on that one, passing my navigator to Paul, he also cleared it with 0 penalties
Event 3 - Run away to the Circus, with sticky guns and hoops
This was the first quarter of the old Slalom course, but this time we had to stop at 5 points, shooting the traditional licker sticker type bullets at targets, straight over the finish line, loop round and back through the start to chuck hoops (old fan belts) over the cones which the targets hung from
Penalties were for cone hitting still and missing of target/cones
Run 1 - Pretty much like Run1 in the Slalom, I messed up, why, we'll never know. Anyway it was a short and simple mistake that was instantly corrected and didnt do us too bad time wise, having someone hanging out the passenger window with a kids bright orange toy sucker gun was entertaining to watch, I didnt get to see what it was like for me, I was too busy going too fast
Plenty of misses from the gun and the hoops gave us a few penalties but everyone it in the same position, but our time made up for it
Run 2 - Much better run, more targets hit and hoops looped, even faster round the course. I mentioned far too much grip earlier on. Here's why, the car grip gripped so hard on the loop from the finish round to the start, not only did I cock a rear wheel I also started to have front inside wheel lift too, thankfully its an open diff so the momentary break in power put me back on the floor, but then by that time we was already round too, so all was well
We were given a word of caution from everyone that Rob needed to keep inside the car as we did the loop through fear of the car going over.
Run 3 - This time I pushed hard, very very hard, even Rob who isnt normally phased said this time we cornered that wuick he darent hang out the window, which can only mean a good time was in order
Event finish, idle dropped to 500 at best, didnt want to run at all, I'd worked the car hard, but we were done for the day so it could sit and cool down for a bit, I say cool down it was sooooo hot that day I think the external air temperature was the same as the engine temp
Everyone finished their finals runs and it was time for a drink and find some shade or put up with the heat. Spoke to Ady one of the organisers and we clarified where Paul had traveled from. As too many people cleared the blindfolded event they couldn't award anyone with the trophy so it was decided that Paul should get the remaining trophy for travelling such a long way to get here
Event 1 - I came joint 6th with my good friend Colin (Gen6 Celica), to which his misses said "oh for god sake can you two not doing anything without each other", good laugh had to be had, but we got our top 10 so we were delighted,
As the names continued Paul's name popped up in 4th place, great result
Event 2 - Of course no award was to be given so everyone was notified
Event 3 - Running through the results, we did terrible I thought, the names rolled by we had to come approx 10-15th place here, nope 5-10?.. Nope... Top 5
... nope. We won the event
Back to the poorly running car. Had a few people come over to see what was up, tried a few easy fixes, coil was hot, potential vaporisation from the fuel in the lines, all checked out ok but nope still refused to run
So to get home I said to tighten the throttle cable up to keep constant throttle to keep the car alive. Paul spaced out the throttle cable at the pedal with cable ties and I loosened the throttle cable ready to adjust. Start idled at near on 3000rpm
adjusted cable let the carb close a bit, decent idle, time to go home
After just 5 minutes on the road and the fresh blowing over the engine it soon cooled down and the idle picked right up
Quick pull over, cut cable ties off the throttle cable, and normal service was resumed.
Got home to take photos of the car with its bloody well earnt trophy, it nearly died earning it
I really need to start taking more photos and videos of these days out
