I know you would mate its ok.If I was nearer I'd totally be over to help... once its been turned over a few times and flooded, and the fuel pump fuse has subsequently been removed, does it fire at all when cranked over?
We have swapped the ht leads wirh a spare set we have buddy...Try swapping the ht leads between cars (I'm still suspicious of the ignition tbh, it's MUCH easier for a spark to form in just air than in an air/fuel mixture, ESPECIALLY a fuel rich one)
I can check the coil tomo fuel system can be roughly checked by me but I dont have a compression tester.You could try swapping the coil with yours Tom just to be doubley certain... if its not spark, and its not air, that only leaves ignition timing, fueling or compression...
That would worki bet it would fire up with a rope tow tom![]()
lambda takes a minute or 2 to warm up, so does,nt effect start-up ehCould be lambda issue? dunno if been mentioned yet
Ill try a bump start as soon as we can...Just read this...
As frank says, Tow it at 20mph in second with ignition on, see if it fires up
Once this is done it sounds like you need to look into why its (most likely) over fueling. Temp sensor is the first place to start. Remember, there are two sensors, one for dials and one for ECU. you want the two wire one (for ECU). I would replace it to see if that makes a difference, Im sure someone will have a spare knocking about, I do but its at home :\
Same mate nothing after a long tow bump at 20 mph tryed 5 times but nothingHeyaa azzynope nothing... Two weeks and she's still dead :/ however we will be bumping her tomorrow and if that fails.... We will change the sensors
x
It's defo not temp sensorsPicking up new temp sensor tomorrow![]()
it was a injector fuse wiring near the battery tray so check with volt meterWhat is it then? X
I was only commenting on my faults as a ref, it can be anything only a idea of helpJust because that's what was wrong with your car doesn't mean it's what's wrong with her car.
Might have these off you Scott if Chloe doesn'tI have both coolant sensors spare. You can have them for cost of postage. Brand new never used.
Sent from my HTC One using Tapatalk
That's cars all over the road/verge/field![]()
I'm sure you commented on itOoooo what one ? X
Something on the lines of out with the grey and in with the funk?![]()
Phew... because I was a out of ideasAaaaa so I didI remember now x
