If you're asking this many questions, you're a long way off having a sucessful turbo build.I need help on what parts to use to turbo a micra k11,
And what turbo can be used on low boost? What to do ?
What about mapping? It isn't cheap (£500 thereabouts)I can make a manifold, can do rest of work just need to know if I can use a tdi turbo am on budget build
Flick through some threads. SirChris has a nice turbo thread goingI can get that done after that's not a problem
google dont show you ever parts that people have done to there micra which I can get help on here
Got nothing I can help you with I'm afraid, I do have a turbo mani but I see a turbo conversion in my futureyes mate I need few bits and bolt if your local
the actuator is just 2 bolts abdul, there are pics on hereis that easy to do, and what is better t25 or gt15 tdi ? Can you make me a manifold frank ?
stani cut his rail down mate (shortened it) checkout his blogthanks frank, do u know how to make the sr fuel rail to take 370cc injectors ?
i doubt it mate, minimum 250cc at a guessor 1.6 ga will do ?
just read all the turbo threads on here matefrank can I come to Bham tommow after 11 am to visit you thanks
Weld a flang onto the micra manifold, bolt the turbo on for gods sakes lolOk mate ill defo buy a td04 turbo then and weld it on a micra manifold ?
a hobby mig is too small for welding a cast mani really mate, but would weld the rail ok tho (they are awkward to weld without getting leaks tho !)I have a wolf mig welder with gas is that ok to weld turbo flange on mani ? Also can I use that to make a fuel rail weld ?
Can anyone do me the job frank ?
if you wanna tack the mani in position abdul, i can weld it securely if you wantCan anyone do me the job frank ?
Ok get to me it's Abdul 07516889335
yes I want one done frank so I can pick it up,If you want it feel free to pm me
