Good day all.
Big up to Baz, Duncan, Ed, frank and the rest of you guys that helped me get the car together.
Its been a little over a year of flawless service from this engine and many, many miles of driving like I stole it.
Finally, it seems to have developed some sort of condition;
It does not smoke.
No coolant loss or overheating.
I have been getting a stumble / misfire over the last 2 weeks when the car is cold and driving with 5 psi boost or more. When it warms up it is good. Problem has progressed to the extent that the car now idles poorly.
The vacuum is low but not fluctuating at idle.
The exhaust is sooty and black and I believe that the gas consumption has gone up a bit - approximately 20-30 % from last year driving the same route.
I have checked the plugs. They were black but did not seem shot. I changed them anyway, along with plug wires / leads, and distributor cap. ( B12 sentra works) Could not get a rotor so I just cleaned up the one I had. Will probably look into ordering a set for the figaro. I confirmed that I do not have any piping leaks or vacuum leaks. ECU flashes back code 55 - no error.
I also read that in mode 1, the green led is supposed to flash 6-8 times within 10 sec if the O2 sensor is good. This I am not seeing.
Has anyone here on the forum noted if they suffered similar problems before finding that their O2 sensor is shot or can anyone say whether this is typical?
Regards,
sleeper
