Next on the list is to just get it sitting on some nice rims and sort out the interior..Nice motor shame bout the rust any other plans for her?
lee k0011 said:Four in total on mine. But it was a pig to get off.. Every thing had just rusted solid in to one lump, so it had to be cut off instead of just unbolted..
But worth the hassle as the rattle was doing my head in.. Sounds so much better now, especially at high revs..
Yep perfectly safe in my experience..Fitted a new down pipe to my sisters K11 about three years ago,and never put a heat shield on that. That has done 200 mile trips with no problems at all..So you have no exhaust shield then? Is that safe? Mines annoying me slightly
Any way. i thought you had a Janspeed on yours ??
My exhaust has no heat shields on it now..Oh I thought it was the heatshield further back, towards the centre pipe bend and backbox. I have a bit removed but faf putting it back, just laziness really.
Yes but there wasn't a hole there when i jacked it up. Only went under there to paint over an old repair and ended up with this . Moved the jack sharpish tho after i released..Hang on... Are you jacking it up under that rusty panel?
If you can do it gor the cost of the welder and labour in 200 quid. Fix her. If more shoot her for airplane meat. Once you have rust its a losing battle.Yes but there wasn't a hole there when i jacked it up. Only went under there to paint over an old repair and ended up with this . Moved the jack sharpish tho after i released..
So the plans now are ether to buy a welder and sort it my self, or i have found another pre face lift not far away, with only 40K on the clock.
Reluctant the later tho, as i have put alot of work in to this one.
Oh and i did find two other patches, but they are not structural so nothing to worry about ..
No nothing stolen, Just plain vandalism.Anything been stolen?
Such a massive pain when this happens, £70 isn't bad but that's besides the point.
Only a tiny scratch where the rock hit it.. But it hit on a strong part of the body,so no dent..BAS-TARDS! Any damage to the multipla?
Had this done to a couple of my cars over the years..sharing your sorrows.
they only upset cause the cars looking realy good man,,,,,,twats
All welded now. And i sprayed a load of wax oil down the sill when it was open like that to stop rust any way..need to get it sorted asap man otherwise the inside of the sill will start to rot.
This was a pain of a job to do with the car on the ground tbh.Good fight going on with this K11 , keep it up!
I´ve welded a dozen datsuns and nissans back to life (including that blackmask K11 i use as a daily driver for this winter), it can be boring sometimes but pays the price at the end for sure!
No more whole
Welding wasn't the neatest tbh, but it was solid enough to be hit with a hammer and not budge..
Put plenty of underseale on it to keep it rust free..
lets just hope the M,O,T man is happy with it..
Hope it isn't as bad as mine was dude!Looks like a winner
Found out today that mine has also some rust issues at the same place
Well not to worry, steel is cheap.
I am about to do my rocker cover like yours, couple of questions for you.Rocker cover on..
I used masking tape. But if i were to do it again, i would just sand after painting. Looks a lot simpler, and saves time..I am about to do my rocker cover like yours, couple of questions for you.
Did you mask the writing or just sand it down after painting?
What allen bolts did you use, the OEM screwsa are a bit too manky to reuse.
Not sure about the bolts tho. Got loads of them from building bikes. I think they are about 25mm long, but cant remember the thread size sorry..
Thanks, will paint and sand back then. Anyone else know a suitable bolt ?
Sorry mate there M6 for sure, doh!Thanks
Yer got that sorted the day it happened bud..Have you got that rear window sorted yet Lee?
Gooood luckM.O.T booked for Saturday..
Wish me luck ppl
I have got my eye on a couple of other micras. But it would brake my hart to scrap itnice another person from north wales!
on another note, reguarding the welding, i suppose it depends on what its going to cost to fix :/
sometimes its better to cut your losses and start again on something better
