late type k10 running ecc ecu system
bobsp16
Site Supporter
ed or whoever could help me on this one
Right the ign system on the late 1.2 k10,s which uses the ecu some will say its a better performer and could be remapable system,against the older distributer/vacume setup
Would it be possable to run the standard late ecc distributer and ecu on an earlyer k10 model but only using the ignition side i no you would have to run the map and lamda senser but not all the cat and emissions system.
if it could it would be a good system for say twin carbs/bike carb setup
Bob still better and much simpler just to get a small ignition ecu.
You thinking of running an ignition ECU BOB?
Sounds like the system ED mentioned is best (alpha-n I think). Use dizzy from late K10 ECC for sensor, if I had the money I would do this, perhaps in the summer if ED gives me some more help/advice.
in the past i have had this system around 4 times and put it all in a skip,now iam gunna go out and buy a late k10 which has this ecu run ignition and start stripping all the emission side wilst still keeping it running.
all i want is to end up with the ecu and its distributer with only 2 or 3 sensers and not all that emissions crap
