Key code for radio/cd player
Hello,
The battery recently went flat on my 2006 Nissan Micra. I have removed the radio to get the serial number:
Blaupunkt-Werke-GMBH
Serial number: BP5387 6 9679245
Part number: 7645387318
It would be amazing if someone could send me the code for this!
Many thanks
G
Hi wondered if you could help me please. Lost code to radio but have just had alternator fitted and now radio needs code. I have codes BP536556438243 and 8635123520 1. Thank you
Hi Deborah, try 8773, or if that fails 0773
Hi folks wonder if anyone can help me out with the code for the head unit in my k12 Micra.
BP53655644561
Other number I can see is
59730011716
Any help will be gratefully received thanks.Alex
Hi John,
Could you provide the code for the following radio: Blaupunkt: BP536556438076 Part No: 7645365318
Would be getting me out of some hot water with the wife :(
Richard
Hi John thank you but I cant seem to get rid of wait 1 hr we tried disconnecting the battery. Can you help please? X
What is not obvious is that you have to wait for one hour with the ignition AND the radio turned on. So best bet is start the car, turn on the radio and go for a leisurely drive and magically the 'wait for one hour' message will eventually turn off while you are driving.....
Hi any chance someone can help with my radio code for my nissan micra.
The serial is PP3000MB0003755
Part number 28184BG0DA
Hello!
I'd be very grateful if anyone could help with the following:
Blaupunkt-Werke GMBH (Made in Portugal)
Serial number: BP6340X5838937
Part number: 7 646 340 318
Many thanks
Alex
Hello!
Many thanks
Alex
Hi Alex, try 8568, or failing that, 0568
John....
Hi guys,
I’d also be really grateful if someone could help me with the following stereo code from my daughters Nissan:
Serial: BP538469511035
Part No: 7645384318
Many thanks in advance
Kindest regards
Ben
Hello,
I'd really appreciate it if someone could provide a code for my nissan micra radio:
Serial number: BP334958126907
Part number: 7643349318
Many thanks
Matt
Hi guys,
Part No: 7645384318
Kindest regards
Ben
Try 5394 or 1394
Thanks for the reply, however, This doesn’t seem to work, am I right in thinking you press the up tuner to enter the code once the numbers have been selected?
Depends on which model radio/CD player is fitted, post picture of the front of yours and hopefully can get code input procedure.
Hi John,
Disconnected the battery to replace the rear door harness from the rear pillar back as it had broken wires at the hinge where a previous owner had bodged a repair... forgot about the radio code that we don't have for my wifes 2006 1.2S.
Really would appreciate your expertise with this, serial and part numbers are
BP538469498169 ----- 7645384318
Many thanks in advance.
Joe.
Hi John,
Joe.
Hi Joe,
9500 should work, but if that fails 1500 is the alternative
Could you please provide me with the security code of my Nissan Micra CD player which has the following data
Serial number CL 052420007607
part number is PP2424M
Thanks alot
Hello John. I changed the battery (micra 2004) and now blocked the cd radio. Please can you help me to find the code?
BP 334947315483
7643349318
Thanks in advance.
With best reguards
Micromc
Hi would you be able to help me I changed the battery on the daughters radio and I need a code. I have looked everywhere but cant find it.
Blaupunkt
BP538471220527
7645384318
Its a 57 plate
Paul C
Blaupunkt
BP538471220527
7645384318
Its a 57 plate
Paul C
Hi Paul, 1718 would appear to solve your problems
Hi, can any one help.
My mums battery went flat on her 2004 Nissan Micra now needs code
Sticker on back of radio shows
BP334947261240
7643349318
Kind regards Steve
Hi folks,
another one suffering in silence. If anyone could get me the code for the following, it would be much appreciated
BP234732020279
7642347318
Cheers,
Gareth
hi can you with code for 59 plate micra all that comes up is ntec serial number 8824672 devive number 7612830023 thanks in advance Paul
Not the right numbers for me to decode I'm afraid , need the serial number from the back of the unit starting with 'BP'
