K12 Radio Codes
Hi everybody,
i lost my radio code and the battery had to be changed. So no radio at the moment.
BP234756231456
7642347318
Can anyone tell me my code?
Thanks!
Hi Everybody, I am a new owner of a 03 Micra 1.2 sx with no radio! It has a code in the owners service book (5770) but it will not work!
I have read loads of posts about this code problem & I also have tried to solve the riddle.....
I have downloaded the app, but am unable to get it to work!
Please can anyone shine some light on my problem?
BP234631958222
7 642 346 318
When entered, I have the code 4455 !
But I get the 1 hr again......
Thanks in advance, Jess.
Hi, I have done it!
I used the "Blaupunkt calculator v1.0" from https://carradio.wordpress.com/
In the Serial number boxes, I put in the first 4 numbers from my radio code 2,3,4,6 then there is a grey X, so I ignored the 3, then typed in 1,9,5,8,2,2,2. Then Pressed Calculate!
It gave me the code 5726, which I put into the stereo & it finally sprung into life!
Regards, Jess.
Can anyone help me with my 2008 nissan micra radio code?
> CL081680034369
> Part. No. 276-0034-54
> Design - T16509/Z05192
> Type PN-3000
> Part No. 28185 BG10A
> Model No. PP-3001M
Many thanks
I lost my radio code due to new battery can anyoone help with a code for my nissan micra 2003 chassis no SNEAAK12U1150619 please?
Any help much appreciated :):(
Hi Dear.
Just bought a nissan micra 2005. Radio need a code.
FJNFBAK12U3047887
FDKARBFK12EEAKAH-G
THKS
MANU
Need blaupunkt part number and serial number off the back of your stereo/radio unit ;)
Edit:
Example; BPxxxxxxxxxxxx and 7xxxxxxxxx
I changed battery now need radio code :( but I don't know how to remote CD player from the place is there any video? For how to do or any one can help me please?
Sent from my GT-I9300 using Tapatalk 2
Hi! I also needed a code. Anyone know what app to download to get it?
On google play (android) I searched "blaupunkt radio code" and downloaded pretty much the first one that came up
However, I've just had a look now and can't seem to find it :(
Also had a look in app manager on my device and it doesn't tell me the publisher. ...sorry
I'm not sure but the number is : PP3001MB 0011977
Edit : part no 28185 BG10A
Hi Everyone,
|I have a problem with my code. I ve managed to get the serial number and the part number.
Please Help.
Serial Number: BP334947333667
part number: 7643349318
Thank you
I hope someone can help with my radio? car has been in for service and the mechanic had left the battery off, i have managed to remove the radio (6 cd changer) , but there was no sticker on the back
i have noted all distinguishable numbers and codes i could find on the unit, so far i have these:
BP 536556439714
LP 8635123-520-1
LP 8635123-522-1
LP 8635123-524-2
598730001912
NISSAN MMR-IDC-G
28184BC401
HP-3254
I have read that you need a part number, but without the label stuck on the back of the unit i dont think i have this, i really hope it can be done, many thanks in advance :)
Hi Everyone,
Please Help.
Thank you
Try 2053 or 0053 ;)
BP 536556439714
The part number should start 76****** ;)
Unfortunately without it my app can't help, but hopefully someone else can ^_^
Hi
I recently managed to fix my 2005 micra, but the stereo needs a code. Took it out and found lots of codes / serial nos. Don't know which are the ones I need
BP 334947339900
86351233930
28185AX613
55610180903
HP-3123
Anyone know the security code.
Matt
Hi
BP 334947339900
86351233930
28185AX613
55610180903
HP-3123
Matt
Hi mate..
Not sure if you have written the part number correctly(86351233930), you need 10 digit part number which must start with 7.. So if I replace the 8 and 0 with these number 7635123393 the security code I get is 7135.
You can try 7135 and see if that works :)
Hi guys, the battery of my wife's car died and the radio got locked. It's a K12 Micra, 2003, the S/N on the back of the player is:
BP334936383408
7643349318
There are two more numbers as well:
28185АХ613
ZU-9583
Will be much appreciated if someone could help me out with the unlock code.
Cheers!
BP334936383408
7643349318
28185АХ613
ZU-9583
Cheers!
Try 8851
hi,
i am desperately trying to unlock my radio since weeks now. finally i figured out today that the radiopass card i got does not match my radios serial number. could you please tell me the code for
BP3349 5 8148671
7 643 349 318
thanks a lot!
chris
