Hi mate, I can't gen a code from the info u gave us. Serial number is correct but I also need the 10 digit PART NUMBER which starts with 76075..... In order to gen a code.Hello there
I just bought a 2003 Nissan Micra K12 and the radio needs the code.
The radio nr is:
BP234632002733
ST SN : 8 635 123 392.0
M5X6MM MAX
(this are all the digits at the back of the radio, i dont know wich you need so i posted all)![]()
Please if someone can help me with the code i'd be very greatfull)![]()
THNX IN ADVANCE
Andi
Would you please help me with my radio?
Nissan MMR CD-G
7645389318
BP538971322883
Thank you in advance!
It works! Thank you VERY MUCH!! :*:*:*Try 0351 ;-)
Try 0032BP384936367776
7643349318
Pretty please. Car in bits and customer waiting![]()
Hi mate.. Need the part number too.. Starts with 764......Hi all
Battery disconnected and now the wireless not happy.....telling radio pass code to go think again
Now have to put up with my own singing....not pretty ....micra sport plus 2006 bp3349 36387026...... Very grateful for a code to stop the crimes against music and bring some normality back to the Edinburgh city bypass
Try 2214Hi Guys
Appreciate if someone can help me out with a code?
Micra Urbis 2005
BP334958124528
7643349318
Thanks if you can help!
HiHi mate.. Need the part number too.. Starts with 764......
Only other number I can find is 28185AX613 from the pass cardHi mate.. Need the part number too.. Starts with 764......
Hi There
My partner has a K12 and after a battery change the stereo now needs a code which helpfully the previous owner did not provide! It's a Blaupunkt unit and our local Nissan dealer wants £25 to provide the code. They won't accept me giving them the codes, nor my partner turning up in person with the stereo and relevant V5 for the car. Quite a rip off.
Codes on the back as they are written:-
Nissan MM CD-K
7642346318
BP234631961185
Thanks in advance....
Hi.. If you replace the part number 8635123392 to 7635123392... Then the code is 3936. Good luck.Hi everybody,
I lost my radio code and the battery had to be changed. So no radio at the moment.
BP234631985647
8635123392
Can anyone tell me my code?
Thanks in advice!
Hi there, we have lost the code for wife's K12, can you please help me, the model and serial number found on the back of the radio are the following:
NISSAN MMR CD-G
7645362318
BP536258425142
Hi there, I just bought my Micra yesterday and I didn't recieve a code from the last owner. Can you please help me..? please-please-please
NISSAN MMR CD-G
7645389318
BP538971324230
Here you go.. Enjoy
Code: 0493
Try 2716Hello
could someone help with code. .
Micra 2003
Nissan MM CD-K
BP234632006806
7642346318
022458
Thank you!
Great!! Thank you so much!!Try 2716
Try 1080
Hi, could anybody help with the code for my radio?
The numbers I have are:
BP23474608900
7642347318
Many thanks!
Hi,
You are missing ONE number. Please check the serial number again.. (If its 000 at the end of s/n (BP23...) then the code is: 0739)
Could somebody provide me with the code for
BP6340Y6424449
7646340318
Try 6719Could somebody provide me with the code for
BP538369456204
7645383318
Thanks.
the code is correct, thank you azb786Try 6719
Lights left on causing a battery drain which leaves me without a radio BOO! HOO! Not sure if I am going through the correct channels. But wondered if it is possible to generate a code for my dead set.
BP234620851559
Nissan MM CD-K
7642346318
I downloaded BP calc.exe but dont understand it's format being BP - - - - X - - - - - - -
BP (then 4 spaces) X (then 7 spaces)
Hi guys, need help garage disconnected the battery to change starter motor I now need the code for the radio its a 53 plate Micra K12
BP33493635488
7643349318
Thank you
Your missing 1 digit from the S/N. (Start with BP33.... - it should be 14 digit.)
If its 888 at the end then the s/n then the code is: 3359
Try 3701Your right I am sorry, I missed a digit there is a 1 at the end BP334936354881
Hi,
Disconnected the battery to change a headlight and then realised didnt have a code for the radio doh
Can someone help?
Numbers are:
BP234632013477
7642346318
