K11 Piper Cams.
Ed
Fusion Motorsport
MSC Founder
Official MSC Trader
K11 race developed Piper cams.
There are two types available:
Fast road 248 deg in/out 8.77mm lift in 8.72mm lift out +8bhp (on stock engine)
Ultimate road 272 deg in/out 9.07mm lift in 9.02mm lift out +12bhp (on stock engine)
These are regrinds and are 232.65 Inc vat on an EXCHANGE basis (I will need your old cams + they must be in good condition)
To use these you will also need a shim set @ £51.70 These will need to be machined down to the correct clearences for your engine.
Contact me for more info.
That totally depends on the machine shop you have to get these done. I would guess somewhere between £50-100. I have made some enquiries and my local machine shop reckons its about a 4 hour job and worse case would be about £100
Are there any problems with running these on a forced induction setup?
No, not enough interest to make the offer of 260 worth while.
any1 know if any of these are compatible with k11 1.4s 2001 model?
