solarice
ok for those of you whove spent some time looking at the wiring diagram for the micras, or just know what they are looking at...can you tell me what exactly this resistor does. (see pic its marked with a red square)
cos even with it removed from the wiring loom the tacho and the engine still run and idle fine...i was switching it out with another one to test, because it seemed to be causing the rpm spike fault...but now im not so sure (as it seems to do nowt and now im confused lol)
W/R wire goes to ecu pin 3 btw.
Cheers.
Cheers.
