1999 T plate Micra K11 Facelift
Originally 1.0 36,000 miles
Now has a CG13 conversion running original 1.0 box, brand new LUK clutch fitted when swap was done. still have original CG10 engine here.
Primera P11 Airbox
Bosch super 4 plugs
First cat on down pipe has been knocked out
Car is lowered using Matiz front struts with lowered spring cup. rears are corsa B dampers with cut K11 springs. Shortend panhard rod for axle corrextion, all original suspension also included.
currently has 14" renault clio steel whees for a better offset, standard 13" micra steels also included
March K11 front bumper, original uk spec front bumper included
blacked out K11c headlights
LHD rear tail lights for the twin reverse look, original included
tax till august 2013 mot till december 2012
front crossmember fully replaced
no other rust atall on the car
located near cardiff
i want £600 for it as it is with all the original bits included, i also have some upgrade bits yet to fit i will include.
