I need my shed back :)
wehey
I have a tons of stuff just sitting around and I really need the space for a new project.
Let me know what you want. I can post most items.
Gearbox from a 1998 1.3 ( mechanical speedo type)
Is that easy enough to do? I take its a bit bigger than the standard k11?
Yep, just lossen the clamp bolts and fix it lower.. Or just remove it altogether. The box is nearly twice the standard size mate.
You will also need a rocker breather filter, about £5 off fleabay.
Nats mate. (1998)
Pretty sure the looms are interchangeable between nats and non-nats but not 100% on that
Hi @wehey
If the primera airbox is available I want it. Pm me your paypal details :)
If there is a non ac alternator bracket as well :) please
Hi folks. Only just seen all of the replies. Wasn't sent a notification!!
Sorry but the air box is now sold and the alternator bracket was sold with the engine. Sorry :(
Quickie update.
Driveshafts
Clocks
Engine Mounts
Oil Pump
Air Box
Rear Lights
o/s Brake Calliper
All the above are sold :)
No sensible offer refused on anything left.
I have left:
N/S brake calliper
Clutch cable/bracket
Cat
Power steering pump
Brake disks
Water bottle
ECU
Battery tray
Upper and lower chains
Idler sprocket
Water pump
Both looms
Intake mani
Exhaust mani
Sump
Starter motor
Rocker cover
Gearbox sandwich plate
Cam sprockets
Radiator
Gearbox
So basically, I haven't got my shed back yet lol
Really do not want to chuck it all in the skip but time is nearly up
