T tatydt99 Aug 2, 2012 #1 all leads and plugs are fine the dizzy is getting power i think (getting round about 12v to the 2 pin conector but not 100% sure if thats what i should be checking? ) does that mean it is the distributor or could it still be somthing else anything else i should be checking
solarice Ex. Club Member Aug 2, 2012 #3 Last time i ended up with no spark overnight it was dizzy failure.
OP OP T tatydt99 Aug 2, 2012 #4 chains ok ?/ not sure how would i check that Click to expand... Click to expand...
frank Club Member Aug 2, 2012 #5 tatydt99 said: not sure how would i check that Click to expand... under the oil filler cap
OP OP T tatydt99 Aug 2, 2012 #6 frank said: under the oil filler cap Click to expand... yeah its moving when the key gets turned
OP OP T tatydt99 Aug 2, 2012 #7 solarice said: Last time i ended up with no spark overnight it was dizzy failure. Click to expand... i hope its the same for me
Stani1029 Club Member Aug 2, 2012 #8 Will most likely be the dizzy, i had it happen at a petrol station! Car was great, filled it up then it wouldnt start lol
Stani1029 Club Member Aug 2, 2012 #9 Will most likely be the dizzy, i had it happen at a petrol station! Car was great, filled it up then it wouldnt start lol
OP OP T tatydt99 Aug 10, 2012 #10 cheers everyone got a 2nd hand distributor from ebay and everything is working again
