GA16 ECU on a NATS Micra 1.3
Alessandro
Club Member (Trial)
Hi!I have a '97 Micra Super S.I just have GA16 throttle body and injectors but I must fit that.With GA16 ecu can they work?My car have NATS and driver airbag with this ecu the airbag will still works?Thank you!
no, plugging in the ecu will not work directly. nats wiring is different
Yes almost. The question was would it work which it wont :)
Its only ever simple if you can fully understand the wiring.
Ed
If I understand the wiring and I plug the ECU correctly the car will works fine?I will haven't problems with airbag,air con etc...?
no, if you plug it in and it works, it shouldn't affect any of those other systems.
