You cna tell if the throttlebody has been changed if there is a plug dangling and a plate blanking off somehting on the bback of the body - also one of the coolant lines going into it is too small, so a larger piece of hose will be around it.
The injectors - the one by the throttle cable mounting bracket fouls it, so will either be spacered out (the bracket) or the injector will be twisted around.
The ECU is located in the centre console towards the bulkhead, there will be a part numbr on it, if you could post this up (if you can be bothered to check it - it is a bit of a hassle) then we could prob work out what car it was rom.
Hope this helps, Craig
