possibly. I would need to see a print out of an emissions slip, to see where they fail. It could be that slightly changing the fuel pressure may help. However my views are more along the lines of where they put the lambda sensor on the janspeed manifold it doesn't see enough of the engines exhaust, as such it cant maintain closed loop properly. I feel it would probably work better if positioned after the main collector where it would see all four cylinders.
