Been tidying up my garage and found my exedy clutch and light flywheel, had a little play, but couldn't get the 3 locating dowels to line up nicely through the holes - they seem to foul by 1/2 a mill or so - do I need to increase slightly the size of the hole, or is tht normal - they were tight when I refitted the cluth tpo the std fly (heavy!) but went on fine when I tightened the bolts.
Also, the standard fly has a big metal disk behind it, but the light one does not - I assume that I do not need it?
Craig
And a couple of money shots
Craig
