Hi Abby,
Good to have you on here, when is your next rally? I have a photo from the people who had it before you.
Specificaties Nissan Micra kitcar:
Engine
1275 CC CG1.3 type all alloy engine built by Adrian Miller Racing
Kit induction, 4 throttle bodies low and high RPM injection, 8 injector controlled with Pectal T6 engine management. Engine internal components by Peter Vaughan and Nismo, valves, rods and cam shafts to produce 160 BHP
Transmission
Hewland HP2000 6 speed sequential
16" OZ wheels
Brakes
Front Brembo 4 pot calipers with 305 mm vented disc
Rear AP Racing 2 pot calipers solid discs
Suspension
Front: Eibach springs, 50mm diameter, adjustable Bilstein dampers
Rear: Based on standard design, 5 linked rear axle, rose jointed upper and lower link bars and panhard rod, Track increased to 1740 mm from standard, Bilstein coil over adjustable rear dampers, Eibach springs
The link below is it in action nice bit of kit.
http://www.asc.nl/showwmv.aspx?id={F85B7F0A-1CE8-49ED-8A6C-0E08A0618718}_Testdag%20Bitburg%20Low.wmv
