"Running in" seems to be going ok
Bike carbs are slightly slower then the webers, but not by much
At 130miles so far![]()
curtis
mine is just a narrowband setup, so it only gives a small window of air/fuel ratio (about 14.2:1 to 15.2:1 apparently) but it,s still usefull (albeit limited).
i think the 2 outer wires on the sensor are for 12 volts in, and pre-heater, and the middle wire outputs a voltage of 0 to 1v, (0.5v being 14.7:1 mixture).
a wideband sensor has a much wider range, but i think they,re a few bob tho![]()
are the carbs variable venturi (with a rubber diaphram/dashpot thingy) ?
Im pretty sure they are yes, as you can't turn them upside down with fuel in them otherwise the diaphram swells
oo i'll have to have a play about with them..
Its basically a flatspot at low revs, but soon as its picked up the acceleration is really good, if not better then the webers
the webers were good for the whole rev range
Nope...but im looking into getting one...
FFS, no wonder you,ve got no response till 4000.
i usually put some 2" masking tape over the bellmouth,s, then punch a 20mm hole in the middle (you should get instant throttle response then), then gradually open the holes up, to give some idea of jet size, needle setting, filter size and diaphram spring etc
Yep, pretty much it, nothing really happens at 2.5-3K but soon as 4k comes along its power all the way...lol
I do miss the webers now
But if i get the timing sorted and the idle etc done it should be ok
told you so! didnt listen![]()
I had my reasons
pfft you should have sold family members of limbs in order to keep those webbers! you'll likely never see another set again now. dedication to the cause my friend!
*or limbs!
Beeing someone who has also now tried both the webers and bike carbs,, i agree with speedle, the webers are better, but they havent blown me away in comparison. pound for pound the bike carbs are prob better value, and if set up right, i think they could easily give the webers a run for there money.
indeed i agree with you there dave, the webbers dont give alot more HP but they have a better power delivery and power curve IMO plus they are easier to tune and live with day to day
about time we had some updated pics of your project dave!![]()
i never had to use the manual chock on them carbs and never had problems starting them, might be a different story tho when we hit january! as for mpg i cant accuratly say yet as the webers where jetted and tuned to curtis's ma12, i wont get a true picture of mpg untill their tuned to my engine and had some more use. but theres no way there worse than the bike carbs. 35mpg is prob the max on the bike carbs.
mate im lovin my new lower stiffer k10,its like another car,my wheels go off to be refurbed (black steelies)next week then my brand new yokahama adrives go on! IM LOVIN IT!
