Make a induction for the itb, works on the same way
Sent from my ONE E1003 using Tapatalk
All what you need is http://www.demon-tweeks.co.uk/motorsport/vehicle-specific-clutchesStuck micra tb back on, works lovely now
Took it for a drive.......it slips the hybrid cg10/13 clutch
So completely undrivable agaim![]()
Revs so quickly!!
More compression, more power lolI'm using a cg10de gearbox
I had the same setup on the k10 cg13 super turbo......and that didn't slip
So either I have a lot more power.......or the clutch is wrong some how
it might have kicked into some sort of limpmode neil ? and you praps need to rig up the tps to max out at half throttle ?So with the micra tb installed, it works.....disconnected the maf, and it still works
So I guess it's running on a safe map?
I'm thinking the tps I bought was duff, as I can get voltage out of the micra tps now
So if I put the current tps on the bike itbs, would it work? Or is these itbs letting in so much more air now it's gunna lean out the safe map?
Another consideration is to match the size of the throttles to the intake, which is something I got wrong when moving from carbs to ITB's.
The throttle plate should be no bigger than the intake port (32mm iirc on the cg13)
the twin inlet ports probably total about 25mm dont they ? (i forget the size) and add a vacuum port for the brake servo too eh neil![]()
Yeah, i tried driving it the other day without the servo connected........brakes were shocking!
