yes but if you lined up cams 2 and 3 instead of 3 and 2, then the spark will be 180 out and only firing on the leaking injectorAll I did was put the half link on the slack side
Then lined the links to the marks with cyl 1 @ tdc
All lobes point to correct position as in pic previous page
yes the slot may just be 180 out ?Neil look at the rotor arm with the engine at TDC on what you think is cyl1.
you can force it 180 out np mate
Oh bollox, I don't know
What do I do?
heh, been there done that neilRuns but better, drove it too.......was terrible![]()
i guess so mate, a rising rate fuel reg can help tho, it drops the fuel pressure at low throttle/high vacuum, so you can get away with big injectors without bogging down so badlyThink I'm at the limit of what can be done with out mapping it?
I saw them a while back and as far as I could make out they are a Megasquirt knock off. Couldn't find anyone that had used one.
