I do hope no one has turned that wet liner engine over, with the head off and the liners not clamped!!Going by l-jonez pic, mines
Ally deeper
Is the gudgeon pin centre to piston top dimension the same as the original Nissan pistons? A lower deck height would explain the pistons not being near the top of the block at TDC......The engine came from a 1.3 auto car, it has cg13 written on the block. All of the parts I'm using haven't come from any other engine, other than the corsa pistons
Was wondering,beings that it's closed blocked from automatic car, might be more meat on top maybe?
you could raise it with a cga3 crank eh, what c/r were you planning ?
best to calculate the c/r first mate, the cga3 crank gives 1365 cc iircWouldn't take any more off the block then?
332cc with the 1275 crank, and 342cc with the cga3 crank ?Is that with which crank?
