The Haynes manual optimistically suggests to put an M8 bolt through the hole in the disk and slowly tighten it to pull it away from the hub. Only problem is my disk appears to have no such hole . The car is 2001 and with only 25,000 miles on the clock so I guess they've been on there a decade.
I sprayed some penetrating oil into the back and decided to leave it overnight, but if that doesn't work what are my options? If I try to bash it will I mess up my tracking/wheel alignment?
thanks,
Simon.
thanks,
Simon.
