Micra 110
Site Supporter
My car failed the MOT on a few things. One being that the rear lights tend to 'dim' slightly when the Hazards are flashing.
I've checked the lights on 2 of my Micra's and they both do exactly the same thing which is 'Dim' slightly
So now I need you to do something for me please.
What i need you do is actually take the Bulb and Holder from the Rear cluster, switch on the Hazards and sidelights (1st notch) and have a look closely at the Bulb and I want you to give me a definitive answer.
Does it DIM?
YES or NO?
If after viewing the results I see that the Majority 'DIM' when the Hazards flash then I will be printing them off and taking the results down to the Testing station.
Hope you put some input into this as I might be able to get the fail changed.
Thanks in advance
Does it DIM?
YES or NO?
Thanks in advance
