1275 WROTE:
clearly a nice light flywheel in there
frank2 WROTE:
"it was off the scale lean, so hopefully the QG15/18 injectors will fit
mycra WROTE:
"one of a kind frank...
frank2 WROTE:
"mycra WROTE:
"one of a kind frank..."</div>
me, or the mani mycra ?
the bigger injectors have done the trick anyway 100% off the scale rich at WOT (tho with the limits of the narrowband lambda i dont know how rich, so i may need to drop the fuel pressure a tad ?) and fully closed loop at anything other than WOT or lift
LowMicra WROTE:
"they should run cars that are of the similar size not a like they did, big V8 vs. a little 4cyl
LowMicra WROTE:
"Good to see it's not another car pushing 500+hp and it's something that is in the same frame as the micra
LowMicra WROTE:
would love a pic of the engine bay
frank2 WROTE:
it was my-mate asdame low
mycra WROTE:
"frank im have trouble with mine sr20 tb... runs almost perfect tuned but at cold, wont start unless give it 10% throttle and hold rev after for a min or 2...then would hold idle without stalling. atm idle is set to 1100rpm
any ideas?
mycra WROTE:
"right thought so.... my sr20 tb didnt come with it... coolent inlet and out straight through... what model did you get ur t/b.
Thanks Frank
mycra WROTE:
"hahaha fair enough... figured its a s14-> sr20... im so glad there's a solution..would really piss me off the way its going now..
with the sr20 t/b you find dead spots in mid range?
frank2 WROTE:
(it just slips out of closed loop at very very light throttle cruise)
mycra WROTE:
"yeah id say mine is fine at times...if you have it in the right rev range.. just got it back last week. feel a dead spot at 2200 suspecting old sr20 tps... it running march nismo ecu with nistune daughter board.
frank2 WROTE:
no its pulling very strongly throughout mycra, off the scale rich at WOT all the way to the limiter
