LowMicra WROTE:
"What are you running as regards to ignition setup? I see the dizzy is modded? That's why I ask, because if you look at the N2 March Cup car it runs a dizzy and leads?
SSUK WROTE:
"I have one of the March ST type boxes and shafts but have yet to drop the plate LSD standard CG13DE box out to attempt to replace it. <BR><BR>Wondering what extent of modification is required to the bellhousing and rear engine mount....
kovert.k11 WROTE:
"with the forged engine for the forced micra in the process of being built, tmrs and i have commenced another project - this time a naturally aspirated weapon..<BR>thus far, this is what's already in/on, and what bits have been amassed for the job...<BR>installed/done:<BR>TEIN Sports Spec Driving Master Type HA Coilovers<BR>Aspect extractors<BR>Custom 2" Mandrel bend exhaust with Kustom Bitz Performance Weaponry High Flow Race Cats Catalytic Converter and Roxy Semi Titanium Muffler<BR>Whiteline Front & Rear Swaybars, Panhard Rod, Drop Links, Castor Kit & Camber Bolts<BR>JIC Lower Control Arm Brace<BR>Sard FPR<BR>Greddy Oil Catch Can<BR>Volk GR-N 15X6.5" rims (powdercoated black) with Advan 195/50R Semi Slicks <BR>15mm Billet spacers on the front<BR>Recaro Evo 8 seats on Bride rails<BR>JDM Tail Lights and Depo Blk Headlights/Clear indicators (will be swapped for smoked)<BR>Rear wiper removed<BR>ABS & A/C removed<BR>Front and rear guards rolled and flared<BR>Windows tinted sexily<BR><BR>Here's what's to go in...<BR>Hi-comp Japanese built CG13 (revs to 9000rpm) - CG10 pistons, bore/hone, port polish, head skimmed with JUN titanium valve retainers, Nismo valve springs, Nismo metal head gasket, Aspect camshafts (in. 256, ex. 264), Mulholland Adjustable Cam Gears<BR>RS5F31V K10 SuperTurbo Gearbox with Nismo RS5F31V shafts<BR>Keihin FCR39 Carb Kit<BR>Nismo Clutch<BR>JUN 3.6kg flywheel<BR>Autronic SMC & 500R with ignition sensor setup and coils<BR>Mulholland radiator, thermostat and lightweight water pump pulley<BR>Billion Silicone hoses<BR>Trust S13 Oil Cooler Kit (full JDM yo! - haha)<BR>Humphris Rear Adjustable Trailing Arms<BR>Front Tensioners<BR>B-Crews Engine Brace<BR>Power Steer<BR>Cusco Safety21 6-point cage<BR>Complete Nismo bush set<BR>Gti-r front brakes<BR>Defi din mount unit & sensors<BR>Auto Meter Air/Fuel & Juran Exhaust Temp Gauges<BR>Nardi steering wheel and boss kit (& pedals if i can track some down)<BR>C's short shifter<BR>Odyssey battery (relocated to under passenger seat)<BR>JDM front bar & spoiler (w/LED)+Nismo grille, front/rear lip<BR><BR>will continue to update on the progress as the saga unfolds<BR>here's what she looks like presently... feedback most welcome<BR><BR><BR><BR><BR><BR>
no Low, they are not for sale - tmrs is referring to the coilovers that are on my car and the fact that he's only ever seen the one set which are the ones i'm runningLowMicra WROTE:
"turbo march-rolling shell WROTE:
also worth mention is the tein coilovers. anyone interested in buying a set: i've only ever seen one set of this model available..this set.. the normal "cool master" teins are rubbish. "</div>
what are you talking about with this TMRS??
are they for sale?? How Much??
"SSUK WROTE:<BR><BR>"I have one of the March ST type boxes and shafts but have yet to drop the plate LSD standard CG13DE box out to attempt to replace it. <BR><BR>Wondering what extent of modification is required to the bellhousing and rear engine mount...."</DIV><BR><BR>quite a few of the bolt holes had to be slightly modified and machined out. gear selector fork must be removed and replaced with a later model one and/or modified to use the stock k11 linkage, or alternatively could probably use the k10 linkage with the k10 gearbox, rear gearbox mount/engine mount bolts don't line up, redrill engine mount, get longer/shorter bolts as needed.neutral/reverse plugs need rewiring.
SSUK WROTE:
"turbo march-rolling shell WROTE:<BR><BR>"
SSUK WROTE:<BR><BR>"I have one of the March ST type boxes and shafts but have yet to drop the plate LSD standard CG13DE box out to attempt to replace it. <BR><BR>Wondering what extent of modification is required to the bellhousing and rear engine mount...."</DIV><BR><BR>quite a few of the bolt holes had to be slightly modified and machined out. gear selector fork must be removed and replaced with a later model one and/or modified to use the stock k11 linkage, or alternatively could probably use the k10 linkage with the k10 gearbox, rear gearbox mount/engine mount bolts don't line up, redrill engine mount, get longer/shorter bolts as needed.neutral/reverse plugs need rewiring."</DIV><BR><BR>Yeah, I noted the smaller bolting holes in the March box. I was considering to make up some studs to avoid boring out the bellhousing as it's not as meety as the K11 variant. Are they ok overbored to M10?<BR><BR>I didn't note any differenced on the selector fork but I probably wasn't looking that hard. I have a spare K11 box, so a swap isn't an issue.<BR><BR>Regarding the rear engine mount, I guess I will have to get the box up on the car to see the differences in alignment on the rear engine mount.<BR><BR>Thanks for the tips, greatly appreciatedSuper build by the way, the attention to detail and the quality of aluminium parts you have used are exquisite. Have you considered making any of that in kit form for the K11 as a bolt on retrofit? I'd be very interested if you do, I'd sure like some of that gear over here on my track car! We have basically the same setup except for a set of Jenvey throttlebodies instead of the FCRs.
SSUK WROTE:
"Cool, I shall take a look at the boxes when I arrive back in the UK later this month. I live in Norway now, so time on the car is limited.<BR><BR>Regarding kit parts, I was being purely selfish when asking for kit parts and was asking for myself rather than for the massesI'd be more than happy to cover all material costs, plus your time & some kind of markup for gear of that calibre.
SSUK WROTE:
"No worries tmrs, the whole car is aeroquip'd anyway, so I am sure I can conmission someone to do the work. I fear living in another country is going to turn me into a 'chequebook tuner', where I get everyone else to do the work and simply sign off checks for the work.<BR><BR>The only problem is finding someone within a sensible distance, you wouldn't believe how hard it is to find a capable fabricator who can properly weld stainless and make a proper exhaust system etc for a car. It seems people are in trouble financially in the UK but at the same time the motivation for people to work seems really low, very odd!<BR><BR>Will keep my eyes on the build, quite interested in the Japanese built engine and seeing what it puts out and where![]()
no Low, they are not for sale - tmrs is referring to the coilovers that are on my car and the fact that he's only ever seen the one set which are the ones i'm running<BR>
LowMicra WROTE:
"What's with the two leads?
kovert.k11 WROTE:
"even when u provide measurements for custom ignition leads, apparently you can still **** it up and make 2 too short!?!?
"dang. kovert sent me the pics yesterday. my first reaction is where the hell is that going to fit lol. i can't see it but time will tell lol. car is pretty well finished, just waiting on these quads then its plenty of 1st gear skid action
