SSUK WROTE:
"Nice job!! There's something about Aeroquip style fittings, braided lines and aluminium fabrication that looks so darn good
turbo march-rolling shell WROTE:
this project is getting retarded, from what was initially put in an engine to spending mass dollars. hopefully it'll all be over soon and we can move onto bigger and better things. sigh
Thats about 3 years less than you,ve been on here mike, and we,ve yet to see any of your "work"sr20micramike WROTE:
"Has this really taken almost 2 years?............yawn!!
"</div>
Buy a pulsar gtir(for boost) and/or Pulsar VZR(N/A) and be done with it!
kovert.k11 WROTE:
"100kw is the aim
"Jesus, that's keen. I would have been stoked to get a 100
+1! exactly the conversion that TMRS and myself had...we were gobsmacked that something so costly, that was apparently designed for the cg13, required so much dicking around and modification to fit..not good enough really..Jenvey sales pointing out to me that they don't make many kits for the cg13 and aren't used to making something so small doesn't excuse them in my book!SSUK WROTE:
For the money, I would expect it to rubby well bolt on!
SSUK WROTE:
"turbo march-rolling shell WROTE:
"Jesus, that's keen. I would have been stoked to get a 100"</div>
Our last run was 93kW @ 7250rpm on a bone stock CG13DE running 264deg cams, exhaust and Jenveys.....
On the subject of Jenveys, those new style units seem like quite a bodge with all the fiddling you had to do. If you look further up in the thread you can see the differences from the original kit that dates back to the mid 90's and the current one. For the money, I would expect it to rubby well bolt on!
SSUK WROTE:
"Yeah, the QC on that Jenvey kit is non-existent for sure and piss poor in my opinion. I don't know why they changed it from the 'kit' I have. We still had to make the throttle linkage but that was quite simple in comparison to all the fiddling you have clearly had to do. Zero excuse....period!
Headwork on the CG engines is usually met with some disappointment, as most are not pushing the engines enough to warrant it. One really has to be pushing some decent rpm to make any porting worth while. EBB proved that with his 'Maxi EVO' head. It made no more power/torque than an essentially identical car here in the UK even though it had been ported with larger valves, a flowed inlet manifold and all the other stuff he added. Granted, it was coupled in with all the other mods, so it cannot be singled out, however there was nothing there which stood it out from anything done previously.
Whatever the output, it's a killer built car and deserves kudos just for sticking with it and making it all fit together and work. Our engine has been a long time in the making and will just about be a year by the time the head is bolted on and it's ready to collect, (some of us must be bloody mad!)
