It was the actual unit itself. I ended up drilling the rivets out and sorting it. I tapped the holes and screwed it back together. It's fine now.I wonder where the fault with the wiper was?
Sent from my ANE-LX1 using Tapatalk
I'm not going to do a tutorial on building it up, as it's literally just soldering components that are numbered to the board.
Also, this is for a coilpack Micra, not the dizzy one.
OK, maybe some of you would like to know about soldering and how to put components on a pcb. I forget sometimes as I've messed with electronics for 40yrs. If you let me know what you'd like to see/know I can work something out.Ah right okay I see. Was hoping for a tutorial but I understand if its literally just soldering.
I am on a long waiting list for a standalone so it would be very interesting to see if I can do it myself.
Look forward to seeing more posts![]()
Yes you could use it for the dizzy ones. It really is much easier though to fit a 36-1 toothed wheel on the front pully and a sensor. If I get time I'll investigate the dizzy option.Would one work for the dizzy cars?
It can run logic coils but not dumb ones that are fitted to the Micra. To run the Micra coilpacks you need bip373's or a Bosch 0 227 100 211 unit like I use.I guess you could use it for fueling only
Or possibly if it has coil drivers you could block the distributer hole and use it to run coil on plug
I haven't seen what inputs and outputs it has to say either way
I've done some videos of building the Speeduino up and what I use along with how to solder the components on. I need to edit them first.
I'll put them on YouTube and post links.
We'll also need one of these to convert the VR crank sensors ac output into a squarewave digital signal.
Oh, and one of these to connect the Speeduino to the Micra.
It should be OK as long as you have a few mm of pin to solder to.I cut mine off at the bends and I'm in 2 minds as to whether some of the inboard pins may be too short.
At least the ECUs are cheap, so I can always take a heat gun to another one. I'm using one for a patch harness to hook up my standalone...
Just making up the jumper lead from the Speeduino to the ecu loom.
Had to dig out the ecu wiring diagrams again. Not used these since fitting my Megasquirt so long ago.
I'm using the slightly older 0.4.3c board instead of the 0.4.4b. I will have to fit ULN2803a chip in the proto area to give me an additional 4 medium current outputs as I want to use the oem pwm iacv and I'll most probably run out of medium/high current outputs.
The.0.4.4b board already has this modification that's all I think.
As for component quality, they're all OK, you don't need to test any of them.
Steady on there tiger lol. Yes there are more videos on the way. This isn't my day job, so as and when I have time I'll upload more. The next one will be about the patch harness.Finding the videos very useful! Just wondering if there is going to be any more video's on making a plug and play harness or tuning etc?
Thanks![]()
And so the money pit, aka my Micra still needed something else to set it apart from the majority of other one's that you see on the road.
A spoiler. Nothing too garish or extreme, else the kids won't get in it for fear of embarrassment.
Found one, but it was the wrong colour (pearlescent orange) hmmm.
Took it to the body shop and tadaaa.
Just needed to fit it.
Didn't want to drill any holes in the tailgate so I just bonded it with polyurethane adhesive.
Exactly the effect I was looking for.
Ebay, these forums, or probably your best bet is one of the Micra groups on Facebook. Someone's always got one for sale.Hey there, I’ve been looking for a spoiler like this one, any advice? Cheers
Sent from my SM-N986B using Tapatalk
Hey hows your speeduino build gone ? have you solved your pulse issues ? gonna be starting a build with it on a QG15DE conversion, should be the same roughly, would love to know how you got onHow many volts is the pulse you are sending to the rpm gauge ? I just finished my speeduino build and its the only thing i cant figure out .
Had a bit of trouble getting fully sequential to work. Turned out that the cam sensor was killing the crank input. After going through the dual VR conditioner schematics I found the issue.
Had to remove output 2 from the board and all was good.
Here's the first drive vid. Went well I thought.
Enjoyed the project. Hopefully it'll help anyone out that's on a smaller budget.
Looks great how do you tint the rear windscreen without bubbles and where do you buy the tint ? I’ve tried so many times and I can’t get it right thank youNow in more recent times, all new cars seem to have privacy glass in the rear and side windows.
Let's give the Micra a more modern look and feel I think.
£80 and two hours later and I think it looks good.
They did say the rear window of the Micra is one of the hardest to do due to it being curved funnily.
