Retepetsir
King of Subsonic
Hi peeps.
I've now had my 1.3 SR for over 1.5 years, and it's running better than ever. I've made a few more tweaks in the past year and not had a dyno run for quite so time, so thought I'd get it dyno'd again. Some quite pleasing results (well, for me anyway!) as its now running slightly more power than previously.
I've also put the AFR information on the graph to show what that's doing, and it seems to be pretty good, with maximum power being reached with an AFR of 12.8.
The Dynapack system measures power at the hubs, I've put an estimated power @ flywheel plot on the graph based on these calculations (http://www.dyno-power-run.com/dynocalc.shtml) but that can be ignored, it's just a rough idea of how the SR is doing and will never be 100% accurate.
Hopefully this will give an idea of what can be achieved when the fuelling is mapped (using an S-AFC in this case). Fueling compensation is +30% in some parts (!). The previous fuel map was modified using the dyno to gain the best performance setup.
Click the thumbnail for the fullsize graph:
Or click here: http://i13.photobucket.com/albums/a260/retepetsir/MicraSR2009DynoResults.jpg
Main Modifications:
- Custom Powerflow Exhaust
- Custom ITG Induction Setup
- Mapped fueling via Apexi S-AFC
- Janspeed Performance Manifold
- Custom Decat
- Lots of other little tweaks and changes!
Comments welcome! :upside:
Main Modifications:
- Custom Decat
