hey all,
about the same time last year i had a problem with the wife's micra not starting. I cleaned the cam sensor and bingo it was fine.......till now.
She'd been using the car all day at work, stopped at tesco on the way home and when she came out it wouldn't start. Turns over fine, but won't fire. Again.
I went down cleaned the cam sensor, but no joy. Checked fuel and its pumping through the filter like a good 'un, so its not the fuel pump.
I plugged in my code reader....no codes. And no warning lights on the dash. So I gave up cos it was flippin cold and rang the AA.
He came out, tried pulling the fuse for the fuel pump trick...it wasn;t that. But when he tried spraying a bit of easy start into the TB it tried to fire. He reckoned it wasn't getting fuel.
So if it isn't getting fuel and the fuel pump is ok, is there another common fail point? Injector rail? Injectors blocked?
Any ideas appreciated.
