Will the gearbox leak if separated from the engine?
will leak when you remove driveshafts just
if it leaked when you unbolted it from the engine it would have to be a wet clutch .... that only bikes and very old cars use
Good stuff, that is what I was hoping for, can drain the box when it's all separated :)
I managed to drain the gearbox on my brothers car, I was changing the springs the hard way and the driveshaft fell out leaking oil all over the place, I hate the smell of gearbox oil, lol.
Quick tip if your draining it, Make sure you can refill threw the speedo on the gearbox before you drain it, as mine was seized and wouldnt come off.
There is only a filling plug on the 98 onwards boxes, you have to fill the others through the speedo drive hole.
Craig
