Wheels
But a little more is needed from your question, do you want to know diameter, width, offset or general style of the wheel
I've run 13x5 et 40, 13x6 et 20, 13x7 et 10, 14x5.5 et 40, 14x6 et 40, 15x6.5 et 38
Current wheels are 15x6.5 et 38. In my opinion this is the best all round setup, if you want wide wheels you'd be best off following the crowd and put some 13x7 wheels on but you'd need to do arch work with the vast majority of available wheels
Decent 14's are few and far between unless you want custom (expensive), 15's have a massive selection and are generally cheaper but unless you're going silly wide have quite conservative offsets
I'd want them something like this
