sent from space??? whats ?
SHEAR PORN! lol![]()
New shoes![]()
Sits well!!
What springs are you running??
Gaskets are like 5quid, i'll also get some exhaust pasteCan you not use gasket maker scott?
EDIT
Actuallly may be too hot, wonder if you get high temp? stuff
I suppose that aint that bad lolGaskets are like 5quid, i'll also get some exhaust paste![]()
You buying the nistune software and tuning it yourself frank?WDIDT ? fitted up the 1367 corsa piston CGA engine, hopefully my nistuned ecu will arrive back from ED,s this week
he,s installing a "ballpark" basemap chris, i,ll see how it fares on that firstYou buying the nistune software and tuning it yourself frank?
Frank... do you lock your micra up... what do you put the chain round?WDIDT ? fitted up the 1367 corsa piston CGA engine, hopefully my nistuned ecu will arrive back from ED,s this week
yes mate, damn pikey,sFrank... do you lock your micra up... what do you put the chain round?
Know the feelingyes mate, damn pikey,sand around the gate lol
i always leave the shafts/gearchange/starter in chris, and pull the g/box over a bit, but i have binned the tin sandwich plate behind the flywheel thoKnow the feeling
Frank just taken most of the stuff round the engine out...Next is to take the gear box and flywheel housing away from the engine.. suggestions? take the shafts out ? or can I avoid that ?
Ta mate! Given up for the evening. lack of light. Will attempt engine removal tommorrow.i always leave the shafts/gearchange/starter in chris, and pull the g/box over a bit, but i have binned the tin sandwich plate behind the flywheel tho
Sounds like you're making cracking progress Chris. I've just been out assing about with the camera. This is 6 seconds at ISO 100:
Pity it was so dark I didn't notice how not straight it was.
whats with the rings hanging from the rear?Sounds like you're making cracking progress Chris. I've just been out assing about with the camera. This is 6 seconds at ISO 100:
apparently they are handles from subway cars in Tokyowhats with the rings hanging from the rear?
ah i see but where did this idea come from?apparently they are handles from subway cars in Tokyo
i make it 13.5Calculated the offsets for my banded steels, FINALLY!
Fronts: 13x7.5J ET0.5
Rears: 13x8.5J ET-13
Written here, as if in stone to remain forever in time.
WOW ! I cant believe the difference that has made, its a different car loli make it 13.5
WDIDT ? removed the remains of the vibration isolator bush,s from the rear of the engine cradle (the nylon insert had disappeared !) and fitted some more substantial ones![]()
i make it 13.5![]()
the under bar front to back ??WOW ! I cant believe the difference that has made, its a different car lol![]()
Today I...
...am about 75% finished stripping the interior. Going to go black with all the grey plastic, and trying to come up with a plan for the door cards.
Yes matethe under bar front to back ??
Remember to show us what you come up with, particularly if it's light weight!
have you removed the head chris ?Starred at her as I left the drive for work... I WILL GET THE ENGINE OUT TONIGHT
Fitted white LEDs behind the dials. Blue were nice but made important speeds hard to see.
Also fitted blue LEDs to the indicators on the dials so they have nice blue arrows
And I noticed the I do have a space for a fuel light but the bulb and bulb carrier is missing!
