LMFAOWill have to message Meguiars and ask what they recommend for removing 10mm of bird ####
That's on hold at the moment, bleddy missus imming and amming againDavyboy lucky you were thinking about coming to spain becaise thats the only way i could polish yours after haha
Ohhh don't want much thenSaw this on Bumtree...
http://www.gumtree.com/p/car-part-accessories/nissan-micra-for-scarp-2001-plate-/1112112087
Anyone fancy going halvies? I only want the bonnet, tailgate and steelies.... yes @MicraPRO & @Clodo I'm looking at you....
Boot went okay until the primer left an outline
Think I'll just buy a new boot soon...
Never spray to an edge!!! No0b
I'm not spraying the whole boot to have it possibly not match!
It's only a bit of fun and there's a K11 the same colour over the scrappies atm.
I'm going to buy a new pad for the DA and try flatten it out soon. It looks good from a distance!
The plan was to remove the marks in the lacquer from the original boot handle, hence its outside the recess
I did.... But either way wherever I mask I'll end up with that primer leak hahaJust mask more than you think you'll need to paint![]()
fitted my spoiler
Bolted at the top and double sided tape down the sides. Not sure if im gonna take it off and spray it cause the wrap job wasnt great so didnt want to glue it in place yet!Looks good mate did you bolt it on or just glue/silicon??
Andy![]()
OriginalStill looks good mate is it an original Micra Super S spoiler or a after market copy?
Andy![]()
I'm liking that carbon wrap Irish, that's going to be copied I would think. Loving the two tone as well......always looks classy.fitted my spoiler
Its just plain matt black, not carbon but yeah gotta admit i like how the two tone turned out! Sure shes collecting parts from all over the world hahaI'm liking that carbon wrap Irish, that's going to be copied I would think. Loving the two tone as well......always looks classy.
A bit of Cornwall in Ireland YAY c'mon the the Celts![]()
Was thinking about doing that myself. Did you drill holes or glue smd? Can i see a photo with them off? What leds did you use?
Nice. Ill be waiting for that5mm white LEDs. Drilled holes and fitted them behind. I'll post more pics in my blog when I can. I left them at work.
I specifically want the modern look though. Each to there own eh.would look so much better and less like a modern finance car if you done all the chrome bit!
really like this car
Based on those figures does the 1.6 give better performance? Weight to power and all that.Weighed an SR20
Sick of the GA16s are heavier than SRs argument...
SR20 - 202kg
GA16 - 138kg
64 kg difference. Weight of me
May be a few kg discrepancy, the scales cost £3 and fluid quantities etc
So that settles that one
Back in its K10 it goes
On-par Horsepower wiseBased on those figures does the 1.6 give better performance? Weight to power and all that.
most of that difference is in the g/box tho aint it andy, an sr with a CG f/w clutch and g/box would be cool.Weighed an SR20
SR20 - 202kg
GA16 - 138kg
Things are a little calmer here. No flamesuit neededmost of that difference is in the g/box tho aint it andy, an sr with a CG f/w clutch and g/box would be cool.
a CG+t is cooler still tho![]()
i think you will find naff-all difference in weight of the actual engines andy, especially if you fit aftermarket exh mani,s and flywheel assy,s to bothThings are a little calmer here. No flamesuit needed
I haven't weighed the gearbox independently but I will do each on their own when it's out the final time![]()
Worth a look while it's abouti think you will find naff-all difference in weight of the actual engines andy, especially if you fit aftermarket exh mani,s and flywheel assy,s to both
What's a scatter rally ?Won a scatter rally tonight, driving and navving !![]()
New fuel and air filters, new thermostat (high flow), drained coolant and started flushing radiator.
Roof mountings for sand ladders partially built, roof mountings for 8x spotlights built (5 spotlights fitted, remainder waiting for delivery).
Broke windscreenwhile welding the roof rack. Need a new windscreen.
Sump guard mostly done, just needs some reinforcement of the front cross-member as I'm not convinced by it.
Ordered gas shocks and raising springs, should be here by the weekend.
Oh wait, that wasn't todaythat was over the long bank holiday!
As soon as I get the last set of spotlights on, and the tyres fitted... though there are a few preview pics on our facebook feed:When do we get to see some pictures of this beast?
