That don't help lol what calipers lolYep will be doing the conversion at some point this year.
Vernier?That don't help lol what calipers lol
Vernierniernierrrrr callipetsVernier?
Well **** job mate... U not even don't it proper.
Just a pair of standard Micra rear calipers, the rear drums and shoes are very worn and will need replacing at some point in the near future so instead i will fit these as an upgrade.That don't help lol what calipers lol
Best bit of brake upgrade personally.. Even better with the bias delete... Was bossJust a pair of standard Micra rear calipers, the rear drums and shoes are very worn and will need replacing at some point in the near future so instead i will fit these as an upgrade.
What u doing sonengine and gearbox out, seats out, front suspension out, pretty much nothing left of the front end, had the boot struts collapse on me while i was taking out the rear lights and landed on my head haha, then walked into the garage door.
also got some photos i took published in fast car magazine in the readers ride section!
Stripping the red car I'm guessing.. Unless he's having a breakdown and killing Minty.What u doing son
It senses the position of the throttle. That's why it's there.Been driving around for a few weeks with an idle of 1500 to 2000 absolute nightmare, nearly drove into a junction the other night with no engine braking !!!! Been like it since putting in a new TPS
Disconnected the blighter today and the idle came down to 800 ....spot on. Why is it even there? won't be connected again.
Grrr... Knew I should have looked more closely at the box i bought.....
Turns out it s a pre-facelift 1.0 box, and I want a phase 1 facelift box....
Anyone want a pre-facelift 1.0 box ? £50 collect/deliver Aylesbury/Uxbridge areas, may be able to deliver to other areas too.
One day I will get the right box....
How can you tell
1999 1.0 ltr box ideally
ayeis it the 4:1 ratio box your after Matt? You can tell its a 2000 box as it should have the hole in the top for the flywheel sensor.
If its the 1999 the only was is counting the teeth on the CW
Yep that or you can work the ratios using a cluth drive and counting the input turn vs output turns.is it the 4:1 ratio box your after Matt? You can tell its a 2000 box as it should have the hole in the top for the flywheel sensor.
that takes a bit of maths matt, without a 1:1 in the gear clusterYep that or you can work the ratios using a cluth drive and counting the input turn vs output turns.
Easy in a simple spreadsheet.that takes a bit of maths matt, without a 1:1 in the gear cluster
What u doing son
Not a K11 but a great bit of on-board would love to have a data logger and video system like that! (Plus all that power!!!!)
Yes, what was wrong/faulty was the new TPS switch, been disconnected now 3 days....she's running perfect without it.It senses the position of the throttle. That's why it's there.
If you've replaced it and you're having issues. Something has to be wrong, surely.
But without it you must be forcing the ECU to correct / guess something ?Yes, what was wrong/faulty was the new TPS switch, been disconnected now 3 days....she's running perfect without it.
In fact probably the best she has ever run - try it....you never know.
its only a tablet perched on the dash tbh andymy lord frank, how do you do this stuff![]()
its only a tablet perched on the dash tbh andywith nissan datascan for android downloaded onto it
i dont know andy, you would need all the tell-tale lights in view ehwould it pass? ...... meant to say.
Badge is in a box waiting to be painted and stuck back onYou painted over the badge?
