Is [HASHTAG]#broken[/HASHTAG] worse than broken?Yeah my airbox is [HASHTAG]#broken[/HASHTAG] hahaha if I smell burning plastic I know what it is
[HASHTAG]#GA16airboxproblems[/HASHTAG]
YesIs [HASHTAG]#broken[/HASHTAG] worse than broken?![]()
I'll get you some pictures of mine tomorrow. Are all of them hashed or just ours?Yes
Mine was fine.I'll get you some pictures of mine tomorrow. Are all of them hashed or just ours?![]()
Not so much what I did more what happened..
in 8 days I have had 2 punctures, an oil leak dispite no obvious leaks, found out the sunroof leaks and to top it off I now need a new windscreen
so i went to ask jennifers hand in marriage .we all seen she gots the smooth hands opposite to mens ones.I'm sold.
back in 85 that skinny kid marty teef'd her from me but now he body popin so I'm guessing my chance looking better.
So I asked the paa "fling me your daughter na!"he said. "your not on t.v get outa here fool".
then i payed my due savillation jacked the k12 up and teef`d out the wheels.then rode out unmarried and wot not.
is just a story????fling me something na?
What yous smokin bud ?so i went to ask jennifers hand in marriage .we all seen she gots the smooth hands opposite to mens ones.I'm sold.
I have no idea what you just said but it was amusing none the less.
It's like a weird chick flick
I hope your seam welding doesn't mean 1 solid bead of weld? It'll increase their tendency to fail
ehh ?Binned it into a tree...
Silly van driver on the wrong side of the road frank I had to swerve to avoid a head on... and completely spun out left right left right tree...another victim of the frosty roads eh tom![]()
Bodgeable for now frank with being new year, will need a new front frame and a crossmember... 2 new headlights a grill and a super s/sr bumper.repairable tho tom surely ? one of the dutch guy,s had a head-on yesterdayhttp://www.micrafanclub.nl/index.php/topic,15492.570.html
No 1 inch weld, 1 inch no weld or something like that.I hope your seam welding doesn't mean 1 solid bead of weld? It'll increase their tendency to fail
Ill have a look frank it does not look like the engine had moved at all, just having a coffee then will go back out.is there a little kink under the chassis near the alternator pulley tom ?
Good stuffNo 1 inch weld, 1 inch no weld or something like that.
View attachment 39284 got an oil leak but no quite sure where its coming from
Driving to work at 6 this morning and my clutch started riding as I was going up a slight hill in 4th, tried 3rd and started doing it again, tried It on flat and still doing it if I put more throttle down, worked out it only really does it when my cars warming up, got dad to show me where to tighten my clutch cable and done that, still does it though but only 3rd and 4th D:
the oil filter is on tight and there is no leaks coming from abovelooking at the stain under the filter, check if the oil filter is screwed on tight and also if the oil pressure sensor just above the oil filter isn't leaking down.
the bite point should be between 1/4-1/2 way up.
if the bite point is above 1/2 way and it slips under load, you need to loosen the clutch cable end to lower the bite point n allow the pressure plate to grip onto the clutch plate.
if the bite point is below 1/4 way and it slips under load, the clutch might be worn.
I saw my first modded Micra today too!!spotted a matte black micra hacking past dons in melksham, was noisey and had hids and green sidelights, its excited when you see another clapped out micra you dont know haha
A white prefacelift SLX 1.3 5 door with a large japcan in Tesco carpark in Newbury. I got so excited.
A load of welding.... seam welded up the new wishbones to be fitted over the weekend and the ones for the spares kit.
